Results 1 to 5 of 5
    Minneapolis MN
    Hydrostream deck rebuild
    Quick video of the work done on the deck of my Hydrostream rebuild.
  2. Thanks Noah Burns thanked for this post
    Likes Noah Burns, VkingMike liked this post
    Jun 2018
    Floating around
    Awesome! Was the fuel tank mounted under the bow in this hull? Is the pic @ 5 seconds this boat? Where its sitting in the water
    Minneapolis MN
    Yeah, there was a 10gal tank added in front of the foot well to add extra weight to the bow. It would really help keep the nose down when pulling a Solemn skier. They still had 2-6gal portable tanks in the rear. The bow tank was mostly kept full just for weight.
    Jun 2018
    Floating around
    Thats how I want mine to float. The way it is now I couldnt dock it and leave it or it would get swamped! The wing tips dangle right at the water line. My Valero on the other hand floated at least 3" of wing above water line and I though that was too low LOL. Mind you, everything is stuff in the back of mine tbere is nothing in front of the rear seat except the front seats and the steering wheel. Big tank on mine too. Anyways planning on reorganizing some weight but it sure does handle well at speed like this so ???
    Minneapolis MN
    The way this was set up at the time it never had more than a 19p prop on it. Motor bolted to the transom and prop was buried. It was pretty much a dedicated ski boat. It would run 50-55 but handled great at those speeds. My plan in to put some sand bags up front if needed for skiing. Then I can pull them for running faster.
  1. Replies: 0
    Last Post: 07-20-2018, 09:23 PM
  2. What to put between wind screen and deck? (Hydrostream)
    By canuckr in forum Fiberglass and Composites Discussion
    Last Post: 08-30-2017, 10:59 PM
  3. how do you separate the deck from hull on hydrostream?
    By NosBoss in forum Fiberglass and Composites Discussion
    Last Post: 11-05-2012, 08:24 AM
  4. hydrostream vandal core and stringers deck
    By afr in forum Fiberglass and Composites Discussion
    Last Post: 03-25-2012, 12:36 AM
  5. Need help with hardware arrangement, rear sun deck/hatch 20' Hydrostream
    By Quinten in forum General Boating Discussion
    Last Post: 02-08-2009, 09:58 PM
