Results 1 to 10 of 10
Thread: Correct adapter plate for 260
02-08-2020, 09:11 AM #15000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
I have a one piece plate on my boat currently and I can't tell if its the correct plate for a 260. I bought the motor a couple years ago with the plate already on the mid. the motor was a 2.4 200 but I'm switching to a 260. I've compared the plate to a friends 280 plate and they are pretty close but a little different. The biggest differences I've noticed is mine has a 1/2 water hole and the 280 has a 3/4. The 280 also has two plugs on each side and mine does not.
02-08-2020, 09:54 AM #2
That plate is an early 2.5 plate and it will work fine for your 260. 1/2” watertube will also be fine.
The later plate came with the plugs on the sides, have thicker powerhead mounting flange, larger tuner mounting platform and 3/4” watertube. The 280 plate is oval exhaust ports on tuner side.
Those plugs on the side on the later plates were put there to tap in external water pickup.
Dave Strong liked this post
02-09-2020, 05:38 AM #3
justa suggestion.. ya might wanna look for later model clamp. that older "skinny arm" is gonna be a steerin' weak point with horsepower...……
tux974 liked this post
02-09-2020, 05:47 AM #4
Good point Tommy, just saw the bolt in the hole.
02-09-2020, 05:55 AM #5
02-09-2020, 04:05 PM #65000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
I was looking at that also. I have hydraulic steering but I questioned the strength of it with the 260 on there. I have a bracket from a promax that has the fat or heavy duty tiller arm on it but it was originally a three ram clamp. Does the bracket fit the single ram or do I need to look for a new mid altogether?
02-09-2020, 04:48 PM #7
clamp parts interchange is a weak point with me.. I do know that a tiller is clamp (production 3 ram or hi perf. single ram) specific.. and will NOT interchange one with tha other... me?.. i'd hafta find a hi perf. clamp/trim....
02-09-2020, 05:42 PM #8
Shadow, tlwjkw is correct the tiller arms will not interchange. The 3 ram has a shoulder and the single ram does not. Hard to find a clean wide 20” HP tiller and if do do most times will not be cheap.
02-09-2020, 05:59 PM #95000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
Thats what I figured. They did not look like they would interchange just by looking at them. I will have to keep my eyes out for a new mid
02-09-2020, 06:08 PM #10
You do not need a complete mid but some times the complete mid is cheaper. You just need a single ram saddle bracket or just the tiller arm.
Put up a wanted ad looking for a HP wide 20” tiller arm with good splines.
BTW, you can sell your tiller arm as longs as is good to someone that will be using side steering.
KR-15 flywheel - correct colour for flex plate?
By Riverman in forum Technical DiscussionReplies: 10Last Post: 11-25-2010, 06:05 AM -
280 adapter plate vs 260 with oval tuner adapter plate?
By rpm racing in forum Technical DiscussionReplies: 0Last Post: 04-25-2005, 10:06 AM
