Results 1 to 15 of 23
Thread: High speed blow out
02-06-2020, 03:31 PM #1Junior Member
- Apr 2009
- GA
- 7
High speed blow out
Can’t find what I’m looking for so here goes. I have seen what can happen to a mono pad hull when the prop blows out at 80+mph but what about a cat hull if it happens? Single engine fairly light flats boat. Would it track straight most likely? Also, if it does what is procedure? Immediate trim/jack down? Thanks!
02-06-2020, 05:32 PM #2
I've seen STV's hook on blow out just like Allison's. All I have done is turn the wheel against the hook and hold on. Not much time for a anything else.
Quartermaster
XB2002 W/S3000
02-06-2020, 08:54 PM #3Junior Member
- Apr 2009
- GA
- 7
Thanks, not much info on it out there
02-06-2020, 09:04 PM #4
I am by no means an expert in this field but I am pretty certain that any boat (hull design) that has the potential to have a substantial portion of its hull suddenly interact with the water upon loss of prop bite at high speed will hook. Evidently some more violently than others. RR
02-07-2020, 06:27 AM #5
Just plan on something bad will happen.
Capt.Insane-o liked this post
02-07-2020, 08:39 AM #6
Crab angle has a lot to do with blow out too.
Dave Strong, rude tim liked this post
02-07-2020, 01:07 PM #75000 RPM
- Sep 2014
- Florida
- 420
- 15
- 25
- 127
From my experience 21 skater and 20 flats boat both true cats as long as you don’t chop the throttle and are not turning you can just hold the jack plate down nothing crazy happens. In a turn I wouldn’t push it to much if the bow drops it will hook I always run less jack into turns. Anyway be safe out there and where a jacket.
#skaternation
21 rally sport (sold)
21 Cougar (sold)
21 Skater (sold)
24 skater (sold)
21 Armstrong (fishing deck) 250 etec
24 SEB (soon to be laid up)
02-08-2020, 02:05 AM #86000 RPM
- Tennessee River
- 1,097
- 10
- 49
I don't know anything about the hull but.
Blowout means the forward push of the boat has given up and you have no control.
No control means just that.
It might sit down it might turn right.
What to do? Hold on
What not to do is have anybody else in the boat while you are figuring this out.
02-08-2020, 08:02 AM #9
Hydrostreams used to blow out a lot but it was cuz I was usually pushing too hard trying to get more than it had. Never a bad landing. STV blow out was totally different. Complete loss of control but boat went straight as a string. Unfortunately directly at a buoy in this instance finally regaining control 50' short of disaster. Never had it happen in any of the Allisons. Bottom line is posted above. Don't push it with passengers.
RockTeam Junk
rgsauger liked this post
02-08-2020, 09:02 AM #10Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Had my XR2001 blow out twice on me at 112 and 110. Both times it just laid down. The 112 blowout is on video. Blew out my 1/4 Master multiple times, it just laid down until the last one when it pulled a steering cable loose
Erik Kiser
02-08-2020, 09:05 AM #11
Baja170 liked this post
02-08-2020, 09:19 AM #12Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
My pass starts about 1:40 or so. I’m in the white Allison. At about 1100 ft into the run you see the left side of the boat fall and that’s about it. Pretty uneventful unless you’re driving, definitely gets your attention
https://youtu.be/__RDYOUh-i0Erik Kiser
mrichartz thanked for this postCapt.Insane-o, mrichartz liked this post
02-08-2020, 09:36 AM #13
Thanks..it's a good video
Yea anyone who's experienced it can feel/see it in the video and heart best goes up a bit..I won't forget the first time I had it happen..380 Lazer w 2.4 Bridgeport w a little work... it was a very long time ago and remember it like yesterday.. except mine was a bit more violent. luckily other than having to wait for the motor/fuel pump...
shook up so bad had air bubbles? so fuel pump won't prime right away not really sure what it was, was just looking around making sure boat was ok...
Just out of would like to say instinct but..just happened to hit the gas when it was heading straight again and it kept it from getting worse..and stopped.
MichaelLast edited by mrichartz; 02-08-2020 at 09:47 AM.
'84 Checkmate Convincor
02-08-2020, 11:35 AM #14
Erik your just a elite driver, was that the CF boat.
My boat would just shake, never ever a hook of any kind, some people over react, short crisp movesWe have invented the world; WE see
02-08-2020, 12:29 PM #15
remooving low speed/high speed spark advence module
By jmr112 in forum Technical DiscussionReplies: 15Last Post: 12-14-2016, 10:46 PM -
Makita high speed buffer, variable speed
By BUD in forum Non-Marine ItemsReplies: 0Last Post: 10-10-2015, 01:22 PM -
CLE vs Bob's in top speed blow out?
By Valero2.5 in forum General Boating DiscussionReplies: 17Last Post: 11-10-2013, 05:29 AM -
Etec 225HO gearcase blow out speed
By scott reierson in forum Technical DiscussionReplies: 3Last Post: 11-18-2006, 09:16 AM -
Low Speed/High Speed Module
By SeaJay in forum Technical DiscussionReplies: 5Last Post: 12-17-2004, 07:52 AM
