Results 31 to 31 of 31
Thread: How F'd is my crank
02-12-2020, 07:58 PM #31
That can be done ..... get it to a crank specialists .
But it all depends on the cost v a good used one.?
in the states you have masses of good used stuff so its more than likely a lot cheaper to replace.
New Big bearing 2.5 crank (not a 260 style crank)
By GILMORE010 in forum Misc. Parts and AccessoriesReplies: 2Last Post: 02-24-2016, 03:32 PM -
drag crank,has a coller or spacer between bearing and crank is this normal?????
By camaro7081 in forum Technical DiscussionReplies: 29Last Post: 10-22-2009, 09:42 PM -
what is the difference from a 260 crank to a fishing motor crank
By camaro7081 in forum Technical DiscussionReplies: 21Last Post: 02-14-2007, 08:20 PM -
Top Main Crank Bearing/ Rod To Crank Bearings
By mr twister in forum Technical DiscussionReplies: 2Last Post: 09-09-2003, 08:45 AM
