Results 1 to 3 of 3
Thread: 2.4 200 swivel install question
02-03-2020, 10:00 PM #1Junior Member
- Jun 2019
- Miami
So i got a 89 mariner 2.4 200 oc101307 that I took all apart to swap mids cuz I cracked the original one. I've bought almost everything I could replace, solid mounts, bolts, nuts, studs, and everything for the swivel pin. I like doing things right so I notice that they sold me a spacer that belongs to I'm guessing 2.5's that goes by the lower yoke which is #4 on pic#1. Pic#2 is how my swivel should be installed. My question is do I build it like the 2.5 or can I use that spacer on top since the original 2.4 spacer is discontinued?? Or can i not use the spacer??Another thing I noticed is that the seal goes on top and oring goes at the bottom on 2.5's and the opposite for the 2.4. Same thing with the spacer and they're completely different what should I do??
02-04-2020, 03:03 PM #25000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
I think it depends on which swivel pin you use. 1 has a step on top, the other is straight. Also check swivel brkt. 1 will have step in it for seal, the other, a bevel for o-ring.
02-04-2020, 10:16 PM #3Junior Member
- Jun 2019
- Miami
That was the other question I was gona ask..if the o ring went on the bevel top part or under the bevel on top of the top bushing?? Anybody kno what I mean??
Trim ram pin bushing install into swivel bracket
By STV_Keith in forum Technical DiscussionReplies: 3Last Post: 07-30-2019, 08:03 AM -
BOB's LWP install question.?
By dagodiver in forum General Boating DiscussionReplies: 16Last Post: 01-23-2014, 10:05 AM -
Question on Nosecone Install
By T_hess66 in forum Technical DiscussionReplies: 1Last Post: 03-08-2013, 06:44 PM -
Bobs' L/W install question..
By basspastor in forum Technical DiscussionReplies: 4Last Post: 11-21-2011, 06:52 PM -
Question before I install the stringers
By WICKEDRISTER in forum Fiberglass and Composites DiscussionReplies: 15Last Post: 07-19-2007, 09:49 PM
