Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 15 of 83
    What's been done to this Promax??
    So I got this 1995 225 Promax and digging into it I'm discovering some mods. Please define these mods.
    Who's duel stage fiber reeds are these? What was stock reeds?
    Attached Thumbnails Attached Thumbnails 20200203_200616.jpg   20200203_200704.jpg   20200203_200724.jpg   20200203_200751.jpg
    Here is the ecu with 3 diffrent labels.
    225 promax 6
    A22? A77?
    And clearly 2.4 Liter
    Attached Thumbnails Attached Thumbnails 20200203_193144.jpg   20200203_191503.jpg   20200203_193157.jpg   20200203_193223.jpg   20200203_193643.jpg
    Those look to be the stock 2 stage Boysen reeds that came with the PM from Mercury. They are good if new or close to it. They look pretty clean, so maybe they are new so I would leave them alone.
    That ECU is an A6, its one of the first box and since you say its a 95 which is the first year for the PM it is the correct box that came with that motor.
    Do not worry about that 2.4 EFI faded labeling it's also what Mercury sent out to clean up some of their left over 2.4 parts.
    Also those A6 are good ECU/box if it is working properly on all parameters.
    That pic of some numbers look to be from a Chopper prop.
  4. Likes Dave Strong, W2F a V-King liked this post
    TX......somewhere?
    Quote Originally Posted by tux974 View Post
    this thread never hurts ta bring back ever so often...…….
    https://www.screamandfly.com/showthread.php?14153-merc-chopper-part-numbers
    Whoops... that one wasent supposed to be there
    But the other 2 are the back of the ecu and have a faded Sharpie marking of A22 or A77 6700 if you look VERY close
    Maybe someone did something to it, 6700 would be the correct rpm. If you just bought the motor I would get the box checked out.
    Tommy the link not worky...
    TX......somewhere?
    worked once for me but won't now??? guess delete is in order...
  9. #8
    TX......somewhere?
    agree.. back in tha day when tha efi was makin' its debut I had ecu's with all kinda marker and pencil scribed numbers on 'em.. had a few folks say they could identify 'em but was BS back then.. had ta run 'em (dual pyro motors at tha time) ta try an figure it out.. even had a BP with a laser injection that had "0" markin's but a pot on tha back.. it was fun cause no one, (even most merc hi perf guys), even knew tha motor existed……...
  10. #9
    What makes 6 ecu diffrent than others?
    Meaning... what are the characters of a17 vs 27 vs others? What ecu fits a particular need?
  11. #10
    Sep 2017
    Ashland city tn
    I got merc 2 stage reeds from promax stock that r same color ,Click image for larger version.
  12. #11
    Yes, those are the same ones.
    Roadkill, if you decide or need to change them I usually run the CCM single stage and they do well.
  13. Likes Dave Strong liked this post
  14. #12
    Looks like the cages have had some work.
  15. Thanks roadkill636 thanked for this post
  16. #13
    Apr 2017
    Holland,MI
    Quote Originally Posted by roadkill636 View Post
    Here is a good website with lots of answers to your questions. Somewhere on the page is lists every ECU number and what limiter/what it came on.
    http://www.biggerhammer.net/mercury/
  17. #14
    Quote Originally Posted by Dave Strong View Post
    Dave, at first I also thought exactly the same. But after looking it over closely and checking the ones I have here it looks to be stock.
    The way I was able to confirm was the spacing with a loaded set of reeds
    It is hard to tell from his bottom picture angle but the machine work is identical to a stock cut.....I could be wrong.
    Roadkill, 824003 ECU's (Lazer injection) is what the PM's run. Good link that was posted.
    Let me add that an A17 is also a good box. Some do not agree but I can tell you from personal experience they work well when they are good.
  18. Thanks roadkill636 thanked for this post
  19. #15
    Are stock PM pistons cast or forged?
    Big rods or small?
  1. Replies: 0
    Last Post: 04-06-2016, 09:49 PM
  2. Mercury ProMax 225 vs ProMax 225X. What are the differences?
    By stv1991 in forum Technical Discussion
    Last Post: 09-08-2012, 06:20 AM
  3. Top speed gain Promax 300X over Promax 300
    By Toffen in forum General Boating Discussion
    Last Post: 02-08-2004, 05:19 PM
