Results 1 to 15 of 16
    May 2017
    gonzales la.
    prop seal problem
    hay guys this is second set of seals that has done this on my sportmaster any advise would be helpful i have the madefi top seal housings and i don't think I'm over filling the unit thanks Click image for larger version.
ID:	457793Click image for larger version.
    Using the correct seal installer and coating the outer seal surface where it sits in the carrier with red Loctite?
    May 2017
    gonzales la.
    i used mercury installer and loctited them in ran it one trip was all good second trip got back and found the same problem i just dont understand what could be happening
    Aug 2006
    virginia
    [I] There's at least 7 different seals and O rings to replace on that ......then pressure test and vacuum test its the only way to be sure[ATTACH=CONFIG]457821[/ATTACH
    Possible the area the seals go is worn and can't retain the seal properly. The end looks a bit beat up.
    Did you fill the void between the seals with Dow 111?
    May 2017
    gonzales la.
    What is Dow 111
    Quote Originally Posted by 11b View Post
    What is Dow 111
    Think he means Mercury 101, NLA now. They say to use Mercury 2-4-C now.
    Dow 111... put it on every rubber piece in the mota. Even the impeller
    May 2017
    gonzales la.
    Ok gotcha
    Quote Originally Posted by roadkill636 View Post
    Just silicone grease, 101 is the best if you have it but 2-4-C will woek fine.
  12. #12
    May 2001
    Ga
    There is a chance that the exhaust does not have adequate water spray below the tuner exit . When this happens it will overheat the carrier quick . Hf...
  13. Likes powerabout liked this post
  14. #13
    May 2017
    gonzales la.
    i have been running this lower for 2 years with no problems after i added the billet stuff from madefi
    what would cause the over heating if that may be what is happening ???
  15. #14
    May 2001
    Ga
    Drop the lower unit . Rig something to go from your garden hose to adapt to the water tube in your midsection . Turn a little water on and check to see you are getting streams of water below the tuner to cool things off . May need to make a few mods to correct things . We had an after market mid and adapter plate not long ago in the shop , it had a 300 xs on top and the air psi dump hose was plumbed wrong and ran awful . After market stuff sometimes needs a little tweaking . Hf...
  16. #15
    JAX. FLORIDA
    After talking to the shop Tech at Reynolds about the earlier XS sportmasters overheating the seals, I now have Charlie and Ed do a complete seal replacement on mine every Winter. The OH a week ago showed that my gearset/internals still look "Brand New".
    "Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
    I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington
    “I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
    Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
    Allison GSE 300XS
  1. Detwiler Jack Plate Seal Problem
    By Greg G in forum Technical Discussion
    Last Post: 08-05-2015, 06:20 AM
  2. OMC Tech: Prop Shaft seal
    By groundloop in forum Technical Discussion
    Last Post: 07-20-2014, 12:32 AM
  3. Prop shaft seal?
    By LineItUp in forum Technical Discussion
    Last Post: 05-01-2010, 10:24 PM
  4. Prop shaft seal
    By Powerplay25 in forum Technical Discussion
    Last Post: 08-06-2008, 06:10 PM
