Results 1 to 15 of 21
Thread: New engines hitting transom.
02-01-2020, 09:07 PM #15000 RPM
- Feb 2003
- Chicago
- 756
- 10
So I got a pair of yam 150 to replace my 200 hpdi'
s. When I trim it up she hits the transome and did damage to the cover. I was thinking a 2" spacer of sorts would help and also keep my nose out of the water. Mounted on a bracket I have always had no reverse due to the wash hitting the bracket. A limit switch would help not hitting the transom. But my nose would still be sitting in the water. What is the rule of thumb for eng hight
and setback on a bracket ?Last edited by yachter55; 02-01-2020 at 09:17 PM. Reason: Wrong pic
THE BEST PART OF LIFE IS SPENT ON THE WATER
02-01-2020, 09:22 PM #25000 RPM
- Feb 2003
- Chicago
- 756
- 10
02-02-2020, 02:03 PM #35000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
Yamaha has a trim limit module. Visit your local yamaha dealer.
02-03-2020, 09:25 AM #4The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...the Porta-Bracket is the best answer...
02-06-2020, 07:20 PM #55000 RPM
- Feb 2003
- Chicago
- 756
- 10
Well.here is what I did. Cut 13"x 2" square tube. Drilled mounting holes and got longer bolts. Not pretty but it worked. The cover just hit but I thought it was 2 "" too close. An guessament.[ATTACH=CONFG]458095[/ATTACH] Well 1" would of fixed it as I have a 1-1/2" gap at the transome. Till I run it I don't know if it's to high or lo
02-06-2020, 07:21 PM #65000 RPM
- Feb 2003
- Chicago
- 756
- 10
When I'm done with my dash I will splash and let ya know what happens.
02-07-2020, 07:32 PM #7The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
02-07-2020, 07:44 PM #8The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
can't tell from the photo but, what are those two chromy looking things, where the bracket meets the transom?
02-07-2020, 09:20 PM #9
In post above says 13in long 2in square tubing. Pretty much using it for 2 in spacer I think
02-12-2020, 06:59 AM #105000 RPM
- Feb 2003
- Chicago
- 756
- 10
6020 2" square alum .
02-12-2020, 07:22 AM #115000 RPM
- Jan 2004
- Lindenhurst, NY
- 658
- 88
- 64
- 3369
- 267
I have a feeling that engine will crush the hollow tube in the rough. The spacers they sell are solid.
https://bobsmachine.com/product/tran...acers-58-to-2/
phillnjack, Capt.Insane-o liked this post
02-12-2020, 11:04 AM #12
Yea might not happen first time but.. I would definitely buy some solid stainless or aluminum stock that tubing is going to crush and motors going to start bouncing around..
Or at least put solid spacers in the tube
Do you have plastic/lock nut washers on there can't tell from pic?
MichaelLast edited by mrichartz; 02-12-2020 at 11:08 AM.
'84 Checkmate Convincor
02-12-2020, 07:09 PM #13
you would be better off playing it real safe and get 3 or 4 inch jack plates..... 2x2 tube is dangerous .
and having at an angle ( must have at angle for the bolt pattern) is even more dangerous.
with a small jack plate you can also raise it up a few and get better performance and clear everything...
02-12-2020, 09:09 PM #14
02-13-2020, 07:30 AM #15
Kevin_From_NJ liked this post
Who's hitting the gym??(weightloss)
By Mastercraft241 in forum The Scream And Fly LoungeReplies: 10Last Post: 10-03-2008, 08:12 PM -
Hitting the limit
By HighVelocity in forum Props, Setup, and RiggingReplies: 0Last Post: 10-03-2005, 12:22 PM -
hitting the rev. limiter still
By joey jamz in forum Technical DiscussionReplies: 2Last Post: 09-22-2004, 06:58 PM -
Observation on transom heights on old & new Formula 1 engines.
By Raceman in forum General Boating DiscussionReplies: 14Last Post: 10-24-2003, 08:31 PM
