Working Silent Choice exhaust system for Mercruiser 454. I think it works with a small block exhaust, too. Was on a 88 Galaxy 26' boat with a 330HP 454/Bravo 1.
Used, can text you a video I took of it working before I removed it.
Contains the 2 y-pipes, air actuators, air pump, outlets with rear flappers and switch. Hook up power and ground wires and it's working. I would replace the plastic tubing, and one connector screw is missing on one of the air actuators. Both are readily available. Asking $750
ID:	457715Click image for larger version.
ID:	457716Click image for larger version.
ID:	457717Click image for larger version.
ID:	457718Click image for larger version.
ID:	457719Click image for larger version.
ID:	457721Click image for larger version.
ID:	457722Click image for larger version.
