Results 1 to 5 of 5
Thread: Hull Fade and UV protection
01-30-2020, 08:15 PM #1
About mid summer last year(2019) I noticed top deck was starting to fade in spots some. What product and procedure should I use? Also any products to protect from UV which I think is causing the issue.
thxCheckmate 2002 Convincor 270 496 MAG-HO
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
01-30-2020, 09:30 PM #2
You can buy all the snake oil you want, but in the end the only thing that truly works is a boat cover (A garage is ok too)
99fxst99 liked this post
02-01-2020, 03:09 PM #35000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
The boat should be out of direct sunlight - and use compound on the area that is getting dull . I like to wash the hull after buffing to remove compound spatter and i use an old toothbrush to get out of crevices - after washing - dry and apply some wax to seal it . Be carefull once wax and if its wet with water will be wipeout city
02-03-2020, 01:12 PM #4
3M makes good polish but must use a good wax after polishing. If the cloudy areas keep coming back will need to wet sand before polishing to remove the dead gel. Also as was said keep boat covered when not in use.
03-09-2020, 09:00 AM #5
Has anyone used products from this place? reviews looks good along with youtube videos
https://shurhold.com/Checkmate 2002 Convincor 270 496 MAG-HO
do any gel colors fade worse over time?
By David in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 10-18-2015, 04:38 PM -
MOVED: Vessel hull design protection - points to ponder
By BK in forum General Boating DiscussionReplies: 242Last Post: 12-15-2003, 05:51 PM -
Removing stickers and fade?
By skydog in forum General Boating DiscussionReplies: 4Last Post: 05-01-2002, 12:32 AM
