Results 1 to 12 of 12
    Feb 2019
    Tn
    rookie needs help
    Hi ,
    Ive got a 87 or 88 mariner 115 inline 6 that I just rebuilt carbs on. serial number is OB350689. This motor does not have a dist, it has 2 switch boxes. Can someone give me the timing specs for this so I can do a link and sync. Dumb question but should the trigger for max advance go alway to stop when throttle is opened without the motor started, mine does not didn't know if that is normal or not? Also need octane and oil recommendations.
    Thanks a lot
  2. Likes Glasstream15 liked this post
    You need a manual and follow the entire procedure for the link and sync, way more to it that hanging a timing light on it and checking.
  4. Likes Glasstream15, wogi liked this post
  5. #3
    May 2006
    Sugar Grove IL./Eagle River WI.
    Burn at least 91 octane, ethanol free if possible. I run a little fat on oil-a couple extra oz.per 6 gal. Make sure your water pump impeller is good, the top cylinder needs water. I backed my max timing off a couple degrees just to be safe. Do not lug your motor with too big a prop, they like to spin. Like Dave said ... get a manual.
  6. Likes Glasstream15, wogi liked this post
  7. #4
    Feb 2019
    Tn
    Serial number is OB 357903 what manual do I need and where is the best place to get them? Are you talking clymers or a factory manual?
    Sep 2017
    ontario
    stay on this and see if someone will send you a page of manual for the linc and sync . and possibly walk you through the process for timing . Hopefully soon for you -
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Biskitboy View Post
    Get the merc , clymers and such can give false info
  10. Likes Glasstream15, wogi liked this post
  11. #7
    Oct 2013
    east tennesse
    Only use MERCURY MANUALS just my thought
    Quote Originally Posted by Merc 2.5 View Post
  12. Likes wogi liked this post
  13. #8
    Sep 2017
    Ashland city tn
    Quote Originally Posted by vtboy View Post
    Ya same thing I said. the rest have gave false info on things , I've experienced. They r more expensive tho but u can fix anything on ur motrin with it. Good luck
  14. Likes wogi liked this post
  15. #9
    Black Creek WI
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
  16. #10
    Black Creek WI
    Quote Originally Posted by SS170 View Post
    Good advice IMO
  17. #11
    Dec 2008
    Coldspring, TX
    I buy a lot of OEM Mercury factory service manuals on eBay. As others have said stay away from the aftermarket manuals.
    Also if you can get 100LL aviation fuel that engine will run forever. The Merc inlines love av gas!
  18. #12
    Oct 2013
    east tennesse
    I LOVE THE SMELL of race fuel , 2 stroke SECOND, NOTHING like Nitro RUN THE BEST you can afford its only your engine
    Quote Originally Posted by rhardwick View Post
  1. Help, I'm a rookie at this!
    By DaddyNtzzz in forum Props, Setup, and Rigging
    Last Post: 08-08-2007, 12:58 PM
  2. Help, I'm a rookie at this!
    Last Post: 08-05-2007, 08:52 PM
  3. I'm a Rookie ....
    By Johnny-X in forum General Boating Discussion
    Last Post: 04-24-2006, 01:43 PM
  4. Help A Rookie Out
    By baja1975 in forum Props, Setup, and Rigging
    Last Post: 04-10-2005, 10:26 PM
  5. Help a Rookie?
    By Need4spd in forum Technical Discussion
    Last Post: 02-08-2002, 12:06 PM
