Results 1 to 4 of 4
Thread: carbs
01-25-2020, 10:08 PM #1Member
- Sep 2008
- Arkansas
- 57
carbs
going thru bunch 2.4 and on 7 petal reed the carbs was wh 13 was wondering what those carbs came out on
01-26-2020, 05:28 AM #2
R they round bowls? Do they have the enrichment fittings?
01-26-2020, 07:33 AM #3
The jet chart shows staggered jetting in those so probably'80-'82 200 or 225 based on the jetting and number based on other carbs I've seen. Probably square bowls with orange/brown foam floats.
01-26-2020, 07:55 AM #4
Reason I asked bout bowls , I had set (cant member )exactly but wanna say they were 13 with round bowl ,could had been 18s tho , which round bowls came pre 82 83, without enrichment, used old school choke
OMC Tech: Older 75hp evinrude carbs vs 86' 70hp johnson carbs
By roycesrolls in forum Technical DiscussionReplies: 2Last Post: 06-01-2012, 08:24 PM -
OMC Tech: 1989 looper 140 carbs-swap to 94-up carbs?
By gregr1971 in forum Technical DiscussionReplies: 3Last Post: 04-10-2012, 01:16 PM
