Results 1 to 12 of 12
    Plainville, CT
    Lower Unit Leak Test
    What is a good spec to go by for leak testing a Mercury V6 LU. I have a gauge and bicycle pump setup ready to go. I'm thinking something like 5lbs for 10 seconds, but not sure.
    Also, which seal is most likely to leak? I'm thinking the one on the prop shaft.
    Western Pennsylvania
    I'm going to say PSI shouldn't drop at all over time?
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  3. Thanks Glastron1987 thanked for this post
    Aug 2012
    Tenkiller Lake, OK
    It should hold 10 to 15 PSI for 15 seconds while moving the shift shaft front to back according to the Merc. manual.
  5. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
    Jun 2004
    Alva Fl
    Its good to also test the gearcase under a vacuum as well. Gear case gets hot from running especially if your surfacing, then when you stop it cools down due to water temperature. That's when you can get some water incursion into the case as the cooling pulls the water into the case past any weak seals you may have.
  7. Thanks Glastron1987 thanked for this post
    Plainville, CT
    Quote Originally Posted by Beak Boater View Post
    What kind of tool is used for that?
    minocqua, wis
    Pump it to 15 lbs turn prop shaft any change time for seals
  10. Thanks Glastron1987 thanked for this post
  11. #7
    Ft. Lauderdale, Fl
  12. Thanks Glastron1987 thanked for this post
  13. #8
    Nov 2019
    Canada
    I've always done them at 15psi, turned all of the shafts, then left it for 5-10 minutes. If no drop, good to go.
    www.InjectorService.com
    Call/Text - 204-326-0390
  14. Thanks Glastron1987 thanked for this post
  15. #9
    15psi if we can let them sit for at least an hour, also should hold 15" of vac.
  16. Thanks Glastron1987 thanked for this post
    Likes Glastron1987, InjectorService liked this post
  17. #10
    Plainville, CT
    Well to start my rear one leaks. Doesn't hold anywhere near 15psi.
  18. Likes InjectorService liked this post
  19. #11
    Plainville, CT
    Finally got this lower unit back together with new seals. The rear seams fine now, and the shift seals seem fine too, but the one under the pump seems to be leaking. I hear air escaping from that area when I pump it up and pressure doesn't hold. Is this normal at all. If not, what would be a fix? I cleaned the surface where the new oring seats as good as I could.
  20. #12
    Plainville, CT
    The source of the leaking was not so apparrent, but after the retaining ring got tightened up good it started to hold pressure real nice.
  1. OMC Tech: Lower unit leak
    By laserfish in forum Technical Discussion
    Last Post: 09-18-2009, 04:38 AM
  2. Yamaha Tech: lower unit leak
    By afr in forum Technical Discussion
    Last Post: 02-17-2009, 07:04 AM
  3. lower unit oil leak?
    By Slowroll in forum Technical Discussion
    Last Post: 08-06-2006, 09:07 PM
  4. lower unit oil leak
    By MIKE OSBORNE in forum Technical Discussion
    Last Post: 09-01-2004, 08:12 AM
  5. Please describe the lower unit leak test
    By 4Speed in forum Technical Discussion
    Last Post: 07-13-2003, 07:43 PM
