Results 1 to 12 of 12
Thread: Lower Unit Leak Test
01-25-2020, 01:32 PM #15000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
What is a good spec to go by for leak testing a Mercury V6 LU. I have a gauge and bicycle pump setup ready to go. I'm thinking something like 5lbs for 10 seconds, but not sure.
Also, which seal is most likely to leak? I'm thinking the one on the prop shaft.
01-25-2020, 02:09 PM #2
I'm going to say PSI shouldn't drop at all over time?
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
Glastron1987 thanked for this post
01-25-2020, 03:42 PM #3
It should hold 10 to 15 PSI for 15 seconds while moving the shift shaft front to back according to the Merc. manual.
Glastron1987 thanked for this postGlastron1987 liked this post
01-25-2020, 04:12 PM #4
Its good to also test the gearcase under a vacuum as well. Gear case gets hot from running especially if your surfacing, then when you stop it cools down due to water temperature. That's when you can get some water incursion into the case as the cooling pulls the water into the case past any weak seals you may have.
01-25-2020, 07:52 PM #55000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
01-25-2020, 09:18 PM #6
Pump it to 15 lbs turn prop shaft any change time for seals
01-26-2020, 08:53 AM #7"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
01-26-2020, 09:41 AM #8
I've always done them at 15psi, turned all of the shafts, then left it for 5-10 minutes. If no drop, good to go.
www.InjectorService.com
Call/Text - 204-326-0390
01-26-2020, 02:28 PM #9
15psi if we can let them sit for at least an hour, also should hold 15" of vac.
Glastron1987 thanked for this postGlastron1987, InjectorService liked this post
01-27-2020, 09:57 PM #105000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Well to start my rear one leaks. Doesn't hold anywhere near 15psi.
04-05-2020, 08:49 PM #115000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Finally got this lower unit back together with new seals. The rear seams fine now, and the shift seals seem fine too, but the one under the pump seems to be leaking. I hear air escaping from that area when I pump it up and pressure doesn't hold. Is this normal at all. If not, what would be a fix? I cleaned the surface where the new oring seats as good as I could.
04-12-2020, 04:13 PM #125000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
OMC Tech: Lower unit leak
By laserfish in forum Technical DiscussionReplies: 7Last Post: 09-18-2009, 04:38 AM -
Yamaha Tech: lower unit leak
By afr in forum Technical DiscussionReplies: 6Last Post: 02-17-2009, 07:04 AM -
lower unit oil leak?
By Slowroll in forum Technical DiscussionReplies: 0Last Post: 08-06-2006, 09:07 PM -
lower unit oil leak
By MIKE OSBORNE in forum Technical DiscussionReplies: 2Last Post: 09-01-2004, 08:12 AM -
Please describe the lower unit leak test
By 4Speed in forum Technical DiscussionReplies: 1Last Post: 07-13-2003, 07:43 PM
