Results 1 to 4 of 4
    Mar 2018
    NJ
    Hoping someone has done this.
    I have a Mercury 245 Carb powerhead that i just picked up about a month ago. I know the correct way to do this is find a 260 efi setup/not so easy to find and when you have the parts that seem like it should work the wheels start turning. I am EFI guy-start easy/run smooth-so my question is. I have a complete 1997 200 EFI wiring harness /pump/tank-7 pedal efi intake and R32 225 promax ecu. Can i do this swap out with out nightmares-should it work correctly/or just stay with carbs. Thank you
    The ecu will be to lean. I did that swap onto a 245 years ago with a brucato ecu and it ran beautiful. If you can run the fuel pump in the boat with a return line it cleans up under the cowl and improves air flow a bit.
  3. Likes Baker343 liked this post
    Mar 2004
    vonore tn.
    Stay with carbs. If the ECU is bad, or goes bad. It,s expensive. If it,s promax style inj. it,s no faster than carbs.
    shreveport,la
    What Capt Insane-O said! That engine will run great with the Laser EFI on it but you’ll need a Brucato ecu and put a good fuel system in the boat. Diamond Marine has a good how-to on fuel systems on their website
    Erik Kiser
  6. Likes Laseraddict liked this post
  1. Not the sign I was hoping to see
    By delgrad59 in forum General Boating Discussion
    Last Post: 07-02-2012, 12:54 PM
  2. hoping up a drag?
    By mercdrag in forum Technical Discussion
    Last Post: 11-24-2007, 10:25 PM
  3. hoping to move south ... need help!!!
    By goodsax in forum General Boating Discussion
    Last Post: 04-30-2003, 03:15 PM
  4. Hoping to get it back in the water
    Last Post: 03-28-2002, 07:32 AM
