Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    Jan 2017
    PA
    Quote Originally Posted by tnelsmn View Post
    I think thats all original. The black gel coat and woven roving makes me think this way. The first set of core pictures looks like it was sealed up well from the factory, nice and dry, and it does have woven roving over top. The second set, not so much. Like you said you'll see more once the floor is up.
    so the transom looks factory to you? had more pictures of the pad core but my iPhone ended up on live mode for pictures and they won't upload.
  2. #17
    Minneapolis MN
    I believe so. Theres a chance the transom is still solid. If it was well sealed when rigged its possible. The wood in the transom and core don't touch anywhere, they're completely separate. So a wet core won't wick into the transom. As always a drill test is the only way to know.
  3. #18
    Jan 2017
    PA
    then I will drill some holes back there too while I’m at it. Where do the transoms rot first on these? And what is the best way to seal the holes I’m making in good core, thinking an epoxy?
  4. #19
    Jun 2018
    Floating around
    Hammer test transom works well for me. I used a finely polished smooth 1oz ball pein hammer and a light grip so the hammer can bounce. I go over the entire outside transom face in a 1" grid starting at the bottom working side to side going up. It bounces quite far if the transoms solid and even a slight imperfection and the hammer wont bounce half as far. If its shot the sound is hollow and little to no bounce.
  5. #20
    Nowthen, Minnesota
    The original transom on my vulture looked like that. That heavy roven stuff with black gel over it. I agree with tnelsmn, to me that all looks original by the looks of the fiberglass and the stray chop strand that look like it came out of a chop gun.
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  6. Likes tnelsmn liked this post
  7. #21
    Minneapolis MN
    I would use whatever resin you use to replace the floor with to fill the drill holes. Catalyze it and fill the holes.
  8. #22
    Jan 2009
    Lafitte, Louisiana/ Beaumont, Texas
    Drilled my viper and thought I was good to go. Center of the pad and most of the core good. Around the perimeter and stakes it was shot. I chose to cut it all out. Wasn't going to chance it. Bottom of the transom and around the mounting holes where wet as well
    Modded Hydrostream Vking
    Hydrostream Vking
    Hydrostream Viper
    Sold, Hydrostream Vector, Allison xb2002
  9. #23
    Jan 2017
    PA
    Decided I’m not fixing this one I just have too much going on to take on a full project
  10. #24
    Jan 2017
    PA
ID:	457762Click image for larger version.
ID:	457763Click image for larger version.
ID:	457764Click image for larger version.
    How does this transom look? it looks different then the pictures of mine but to me just looks like a different style hydrostream used
  1. hydrostream hst core
    By Gassman109 in forum Technical Discussion
    Last Post: 12-07-2016, 08:21 AM
  2. Hydrostream re-core help
    By FusionFab in forum Fiberglass and Composites Discussion
    Last Post: 04-06-2012, 01:34 AM
  3. Hydrostream Venus Re-core
    By hydrohellion in forum Fiberglass and Composites Discussion
    Last Post: 09-27-2010, 08:14 PM
  4. hydrostream core question
    By rollerzonlyone in forum Fiberglass and Composites Discussion
    Last Post: 12-19-2008, 12:54 PM
  5. new core in the hydrostream
    By cuffer22 in forum Fiberglass and Composites Discussion
    Last Post: 03-07-2008, 06:02 PM
