Results 1 to 7 of 7
Thread: Lwp in torque master
01-20-2020, 09:15 AM #1Member
- Dec 2019
- Denmark
- 33
Hi
can anyone tell me we’re to drill the hole in gear case? I have a problem if the intake has to be as shown in the picture cause I get to close to the oil screw. But if I drill were the screwdriver is pointing I get close to were the housing/packing is and I won’t get the same water chamber and I’m not sure if this is okay?
hope it makes sense
01-20-2020, 10:59 AM #25000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
From what it looks like, you are wanting to install the transfer hose. From a LWP nose cone, to the LU hsg. That is the correct place.
01-20-2020, 12:10 PM #3Member
- Dec 2019
- Denmark
- 33
Yes the hose from a transom mounted intake. But I can’t drill the hole as shown on the picture (snatched fro the internet) because of the oil screw. Therefore I want to drill it we’re my screwdriver is pointing but then I get the hole much closer to the housing/gasket. Is that okay?
01-20-2020, 12:17 PM #4Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
3.0 gear case lower fin is cut off to accommodate 1/2 pipe elbow if you drill it that high you ill be out of material to thread for your fittings!!! 3.0 has to have two hose's to cool just my .02
01-20-2020, 12:23 PM #5Member
- Dec 2019
- Denmark
- 33
01-21-2020, 04:46 PM #6Member
- Dec 2019
- Denmark
- 33
Has anyone tried cutting this piece of ??
01-22-2020, 02:51 PM #75000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
Yes BOB,s cuts off front of spray plate, to make room for hose & fittings.
Sport master vs torque master
By Ttl in forum Props, Setup, and RiggingReplies: 11Last Post: 01-13-2020, 06:17 PM -
torque master/sport master prop shaft (not fat shaft)
By heather5520 in forum Posting Questions and SuggestionsReplies: 0Last Post: 07-29-2011, 08:34 AM -
1:75 Sport Master Gears in a Torque Master.
By twig in forum Technical DiscussionReplies: 3Last Post: 06-13-2008, 08:43 AM -
Sports master vs Torque master
By Patmerc in forum Technical DiscussionReplies: 8Last Post: 06-02-2008, 07:36 PM
