Results 1 to 5 of 5
Thread: Omc gearcase
    Aug 2002
    florida
    Omc gearcase
    Just finished up my nosecone on an omc gearcase. Pinion bearing was locking up after 3 revolutions. I assumed it was from tack welding the water inlets. Pulled it apart and installed a new pinion brg. It is going back together but the drive shaft is stiff. I can turn it but never seen or noticed this before. Any body with any advice on this one.
    Galveston County,TEXAS
    welding the water inlets may have caused the pinion bearing bore to shrink and/or go out of round.
    limited skills
    MIAMI FLORIDA
    The Bearing is tapered, did u put it in upside down if the housing is a littlle tight with bearing in wrong it may cause it to be tight. Taper is why they tell u not to drive the old one out the bottom when removing...
  4. Likes Capt.Insane-o liked this post
    May 2001
    Hickory NC
    Agree with H2O and if driven out the bottom you break off the lip. I have welded many over the years but always left them together when doing so. If the bearing is in the correct direction you need to check the case alignment with the factory tool.
    MIAMI FLORIDA
    Mooresville NC, Did you move... I lived there for a while on lake norman
  1. 4,88 diameter gearcase vs 5,44 diameter gearcase speed difference?
    By Toffen in forum Props, Setup, and Rigging
    Last Post: 12-26-2012, 06:46 PM
  2. which gearcase- 2.4 200
    By skintback in forum Technical Discussion
    Last Post: 08-10-2003, 05:42 PM
