Results 1 to 15 of 18
Thread: WH carbs on a 2.5 245
01-18-2020, 09:59 AM #1
So I am trying to find a throttle cam for WH carbs on my 245. The original is for the pumper carbs and the roller on the bottom carb is in the complete wrong spot. When I got the powerhead the cam was upside down to make it work with the WH carbs, but this really messes up the timing and sync to the carbs. I was thinking a Bridgeport carb throttle cam may be the one to use. Anyone have this issue before and a solution? May end up making one.
1973 Viper - sold
1978 Viking - sold
1995 XB02
01-18-2020, 10:26 AM #2
linkage off a 2.4?
01-18-2020, 10:42 AM #3
I think the carb to carb linkage is what was with the WH carbs, but the cam is the 2.5 pumper carbs cam. I think a 2.4 200 and a 2.4 BP cam is the same?
1973 Viper - sold
1978 Viking - sold
1995 XB02
01-18-2020, 10:44 AM #4
01-18-2020, 10:45 AM #5
01-18-2020, 11:25 AM #6
Wouldn't that be a 225?? I think I have a cam for ya. I'll get pics in a bit.
01-18-2020, 11:39 AM #7
Here
01-18-2020, 12:06 PM #8
Will keep that in mind. How much do ya want for it? Would ya send the metal linkage as well? I think the one I have on the 245 is way longer.
1973 Viper - sold
1978 Viking - sold
1995 XB02
01-18-2020, 12:08 PM #9
Looks like it needs to be flipped ,i have wh linkage stuff will take a look
01-18-2020, 01:00 PM #10
The cam does need to be flipped, but the WH roller will be no where close to where the pumper carbs would be. Maybe the pumper carbs roller would fit on a wh carb?
1973 Viper - sold
1978 Viking - sold
1995 XB02
01-19-2020, 06:52 AM #11
you need all three pieces used on horizontal front carb motor (pre '91), linkage, cam, carb roller that had wh series carbs on it.. anything else ya do whats been done with it before ya got it.. souther'n engineer it!
01-19-2020, 08:01 AM #12
I'm wit tommy. the rod from a 2.5 is to small to fit in a 2.4 cam , so u will need 2.4 cam, rod ,and prolly throttle arm. The rod link from arm to cam is bigger on a 2.4
I have quite a bit of linkage stuff for 2fo if u need sumthinLast edited by Merc 2.5; 01-19-2020 at 08:37 AM.
01-19-2020, 09:16 AM #13
Thanks guys. I have some 2.4 stuff to put on it and will see if I need the throttle arm as well. I think they had 2 different lengths linkage/threaded shaft, 6 inch and 4 1/2 inch. Will let ya know Merc 2.5 if I need anything.
1973 Viper - sold
1978 Viking - sold
1995 XB02
01-19-2020, 09:41 AM #14
there also may be a difference in tha anchor bracket as well.. think it is tha way tha two adjustment (throttle and shift) barrel nuts are locked inta tha bracket???
01-26-2020, 07:45 AM #15
200 WHM 1A carbs on a 1990 merc XR4 that had WMH 1A pumper carbs
By BASSCASTER in forum Technical DiscussionReplies: 15Last Post: 07-07-2014, 11:26 AM -
OMC Tech: Older 75hp evinrude carbs vs 86' 70hp johnson carbs
By roycesrolls in forum Technical DiscussionReplies: 2Last Post: 06-01-2012, 08:24 PM
