Results 1 to 7 of 7
    no more autoclaves; a new procedure to heat and fuse laminates
    When these technologies hit the marine industry, we won't be needing autoclaves any longer...
    and for builders who can't afford autoclaves for post-laminate curing, they can begin utilizing post-cure resins
    nanotube blanket can be used to heat the laminates together thereby curing and fusing them together
    A new approach to making airplane parts, minus the massive infrastructure | MIT News
  2. Thanks powerabout thanked for this post
    Central Florida
    Quote Originally Posted by noli View Post
    Just curious, who are boat builders who can afford autoclaves?
    Outerlimits is one
    There are many more
    The good news is for those who can't afford, with this technology, they won't ever need one
    I know of a Builder who's been building boats for 2 decades, he told me frankly that he won't change his procedure....so sad
    8 Post(s)
    Quote Originally Posted by BarryStrawn View Post
    all the custom racing yacht builders
    the NZ yacht Steinlager 2 was 83' long built in autoclave in 1989...powerboats are doing catch up
    Mar 2015
    DFW
    I work for a aerospace company in Texas, we've got some massive 'claves. But some of our new composite rotor systems, they are working on a resin system that cures with lights. The materials are setup and then some kind of light is put on it and that cures the resin almost instantly is what I am told. I have yet to see this process or hear too much about it since it is something we are still using in experimental stuff. Anyone else seen or heard of processes like this?
    8 Post(s)
    Quote Originally Posted by Noah Burns View Post
    yes just read a doc on light cured s glass cloth that you get get so way cheaper, I assume you can get carbon as well?
    Needs a special light so you can work with it under normal lights in your shop
  1. 48" Aeromarine Laminates Challanger mono hull for sale.
    By Baja 252 in forum Radio Contolled Performance Boats
    Last Post: 11-13-2014, 04:37 PM
  2. Helicoil inserts for Laminates
    By aalbert in forum Fiberglass and Composites Discussion
    Last Post: 02-26-2011, 08:53 PM
  3. Do You Up Your Fuse When You Use A Trailer?
    By INXS in forum Technical Discussion
    Last Post: 10-09-2006, 05:17 PM
  4. What amp fuse to use???????
    By Georgia Boy in forum Technical Discussion
    Last Post: 07-02-2004, 09:24 PM
  5. STV Laminates
    By Hooty in forum General Boating Discussion
    Last Post: 02-09-2004, 09:05 PM
