Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
    Bristol, WI
    Here's the setup on my father's old boat. Jenkins mid with factory clamp. Click image for larger version.
ID:	456936Click image for larger version.
    Larry Gempp Jr.
  2. #17
    The taylors are sweet and stronger but there’s more to it than just cutting the clamp. Especially if it’s a 3.4 the adapter needs to be cut machined and re welded. To do it right the clamp brackets should be machined to add new clamp saddles as the factory ones must be cut off. We Make brass or Deleon bushings for tilt pin and tiller arm. It’s almost easier/stronger to use a merc clamp and u get a real trim pump out of the deal. We have done a bunch with merc clamp there’s a few benefits over omc.
    Jenkins also has nice solid upper and lower mounts.
  3. Thanks baxter08 thanked for this post
  4. #18
    Lower yoke, Merc to OMC V-8 with Billet lower mount. Single .500 bolt each side ..
    The reason I asked about the "tuck-under" was i remembered ( barely ) that to even do a 20" they need a shortened cylinder to clear ...
  5. Thanks baja200merk thanked for this post
    Likes Baker343 liked this post
  6. #19
    Jul 2007
    Bermuda
    Thanks that's definitely good info to know for when I'm ready.
    I was thinking of a 2.6L to keep the weight down on the back, should I still explore the merc clamp/trim idea for that motor?
  7. #20
    Depends on what you want to use it for but if I was spending the $$$ the merc clamp is more bang for your buck. Much stronger, easily adjusted trim speed, great factory saddles either way you will want good bushings.
  8. Likes baxter08 liked this post
  9. #21
    Jul 2007
    Bermuda
    boat will be a pleasure weekender. We do offshore racing here but I'm not trying to put a grandsport though that. May catch some chip on the off day, but will try to keep it limited. I'm not trying to hit 3 digit speeds or anything, just want the boat to be a good overall craft for weekend runs. I'm spending the time and money to glass and paint the hull, no sense getting cheap on setup and rigging... (within reason of course)
  10. #22
    Aug 2009
    mpls,mn
    How you adjusting the trim speed if I may ask ?
  11. #23
    With the pressure bypass valves in the pump.
    Extreme case's .. voltage.
  12. Likes racervboat liked this post
  13. #24
    Strait from the mad scientist. This ^^^^^
    slow trim hurts here is a perfect example. Well 200+lbs of fuel on the transom doesn’t help either.
    https://youtu.be/0gA2YrfkjVg
  14. #25
    Aug 2009
    mpls,mn
    Chaz you got a merc part # for the fast valve ? I got two offshore single ram mids both have the round canister style trim pumps one is fast as hell and the other is slow as hell.
  1. Yamaha Tech: Cutting the Can
    By nitrohydro2000 in forum Technical Discussion
    Last Post: 02-07-2011, 01:52 PM
  2. OMC Tech: cutting omc mid
    By brussrude in forum Technical Discussion
    Last Post: 12-23-2010, 04:32 AM
  3. Cutting an e-tec 60 down to a 15''
    By With400 in forum Technical Discussion
    Last Post: 03-29-2010, 06:58 PM
  4. cutting down mid
    By mad man in forum Technical Discussion
    Last Post: 01-03-2010, 03:47 PM
  5. 2.5 Cutting out
    By sst45racing in forum Technical Discussion
    Last Post: 04-23-2003, 10:19 AM
