Results 1 to 10 of 10
Thread: Merc 2.4 piston ring squeezer
01-14-2020, 01:09 PM #1Member
- Oct 2009
- Lake Conroe, Tx
- 63
- 30
Anybody got or know where one is, the factory merc tool. It was solid around and the piston went inside and was easy to install in the block. I had access to one but no longer do. It was a factory merc ring squeezer, not aftermarket. Don't know the part number, but it fit standard bore only. Any body got or know where one is? Thanks
01-14-2020, 06:36 PM #2
Easy enough to have a machine shop make out of a piece of pipe.
01-14-2020, 06:56 PM #3Supporting Vendor
- 11,838
- 163
- 11
- 795
Use a 2.4 sleeve cut and beveled to enter ring ...
Jay @ JSREJay @ JSRE
coffeeguy thanked for this postcarb a rator liked this post
01-14-2020, 07:02 PM #4
I'm packing up **** to move, I think that I may have one, will look tomorrow. I never used one myself, always had good success using a automotive band type with the ratcheting band tensioner, Just my preference, never had a problem, and can use same tool on about any bore size I had to work on. I know others may object, but never failed me. Just my two cents, Call it old school or old fool
1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
outboards4life liked this post
01-14-2020, 07:11 PM #56000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,516
- 429
- 63
- 433
- 450
YOU can use a piece of thin flat stock about 1'' wide brass hardware store item wrap it around piston, add 2'' for tabs, bend ends 90, squeeze two fingers, works like a champ.
01-14-2020, 07:13 PM #6
I’ve got one at work . Call me at Justice marine 706 485 4063 .
01-14-2020, 07:20 PM #7Member
- Oct 2009
- Lake Conroe, Tx
- 63
- 30
Will do, Thanks
01-15-2020, 07:28 AM #8
01-17-2020, 08:45 PM #9
wogi, carb a rator liked this post
01-24-2020, 08:55 AM #10The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
.015 oversized piston ring end gap. 96 merc 200 efi
By Calvin1013 in forum Technical DiscussionReplies: 45Last Post: 09-13-2018, 10:50 PM
