Results 1 to 10 of 10
    Oct 2009
    Lake Conroe, Tx
    Merc 2.4 piston ring squeezer
    Anybody got or know where one is, the factory merc tool. It was solid around and the piston went inside and was easy to install in the block. I had access to one but no longer do. It was a factory merc ring squeezer, not aftermarket. Don't know the part number, but it fit standard bore only. Any body got or know where one is? Thanks
    Easy enough to have a machine shop make out of a piece of pipe.
    Use a 2.4 sleeve cut and beveled to enter ring ...
    Jay @ JSRE
    Jay @ JSRE
  4. Thanks coffeeguy thanked for this post
    Likes carb a rator liked this post
    Black Creek WI
    I'm packing up **** to move, I think that I may have one, will look tomorrow. I never used one myself, always had good success using a automotive band type with the ratcheting band tensioner, Just my preference, never had a problem, and can use same tool on about any bore size I had to work on. I know others may object, but never failed me. Just my two cents, Call it old school or old fool
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
  6. Likes outboards4life liked this post
    Feb 2011
    HUDSON, FLORIDA
    YOU can use a piece of thin flat stock about 1'' wide brass hardware store item wrap it around piston, add 2'' for tabs, bend ends 90, squeeze two fingers, works like a champ.
    May 2001
    Ga
    I’ve got one at work . Call me at Justice marine 706 485 4063 .
    Oct 2009
    Lake Conroe, Tx
    Will do, Thanks
    Sep 2017
    Ashland city tn
    Quote Originally Posted by wogi View Post
    This is what I use. 1 size fits all. Prob b found at any auto parts
    May 2014
    Livingston, Louisiana
    Not what ya looking for, but what I use and really like. It’s quick and have the ability to feel ring gaps are properly seated in retaining pins and can see a small section of the rings at plier end to know they are seated properly before installation. And can use for multiple applications
  12. Likes wogi, carb a rator liked this post
  1. .015 oversized piston ring end gap. 96 merc 200 efi
    By Calvin1013 in forum Technical Discussion
    Last Post: 09-13-2018, 10:50 PM
