Results 1 to 15 of 16
    Verado powerhead conversion
    can a 300 Verado powerhead be mated to to this?
  2. Likes 89LASER liked this post
    make the powerhead lay longitudinal and not vertical
    u will definitely be the first to even think about doing it, I assure u...
    watch this...awesome!
  6. Likes InjectorService liked this post
    This is down the street from you, bolts right up and makes enough power to run the crash box and hydraulic pump.
    As well as probably be cheaper and a lot less disappointing, in the end ...
    https://www.shafiroff.com/chevy-pump...isted-sr20.php
  8. Likes noli, Capt.Insane-o liked this post
    Feb 2014
    Myakka City, FL
    your going to have a tough time laying a verado on its side, its go no where for the oil to get back to the pan then.
    I would say your better off with a 3.0 efi or dfi powerhead.
    1988 Checkmate Starflight Yamaha 3.3L OX66
  10. Likes noli liked this post
  11. #7
    Curious, does anyone know where the oil pan is for the Verados ?
    Anyone have the engine schematics?
  12. #8
    Nov 2019
    Canada
    Its horizontal in the service manual so.......
    Serving Performance Boaters North America Wide!
    PM us here or visit our website!
    http://injectorservice.com
    Forum thread about our services:
    https://www.screamandfly.com/showthread.php?347757-Canadian-Fuel-Injection-Service-North-America-Wide-Testing-Cleaning-Servicing!
  13. Likes noli liked this post
  14. #9
    Pick-up tube, sump is below the engine adapter plate ...
    https://www.mercruiserparts.com/bam/...2715/16769/175
    Oil pump, drive, etc. is above ...
    https://www.mercruiserparts.com/bam/...2715/16769/160
  15. Likes noli liked this post
  16. #10
    Remote oil tank....done!
    next issue please....
  17. #11
    Oil drain back from the crankcase cover and cylinder head, and the separate scavenging pump you will have to run, bell housing, engine coupler and water pump.
  18. #12
    I think the oil will drain back both by gravity and positive flow from source. The oil reservoir will be below the motor.
    an electric non-scavenging oil pump will be used
    fabricate - bell housing, engine coupler
    en electric non-scavenging water pump
  19. #13
    That's a lot of work for 300 horsepower, and you haven't even got to the exhaust yet.
  20. #14
    the exhaust tube is water-jacketed
    Name:  sd517241729-mercury-verado-200-225-250-275-hp-exhaust-tube-assembly-880626t01-11.jpeg
  21. #15
    and a dummy drive for the cam chain due to oil pump removal.
  1. Verado/transom water pickup/powerhead plumbing
    By Steelborn in forum Technical Discussion
    Last Post: 06-25-2018, 07:13 PM
  2. 2008 Mercury Verado 250HP Dressed Powerhead
    By MERCSPEED in forum Outboard Engines
    Last Post: 11-18-2015, 04:45 PM
  3. Mercury Tech: SST120 powerhead EFI conversion
    By madgadget in forum Technical Discussion
    Last Post: 09-03-2013, 08:59 AM
  4. My new scarab w/verado , any upgrades on verado 250 ?
    By cc@100mph in forum General Boating Discussion
    Last Post: 08-03-2010, 06:28 AM
  5. Replies: 68
    Last Post: 02-21-2007, 07:56 AM
