Results 1 to 12 of 12
01-13-2020, 05:30 PM #1
225 Excel hard to start when cold
Hi Folks
I have a strange problem with a motor, it rebuilt it a few years back and its always been like it since then. It takes ages to fire when cold (first start of the day).
It fires immediately from that point on all day with out an issue, run hard with no problems.
The cold start is annoying me now and I'm trying to sort it out and to be honest once teh HPDI is up and running I will sell all of my Excel stuff and this motor needs to fire up quickly for a buyer.
I have put a new starter on as I didn't think it was spinning at 750rpm that it needs.
Battery is always charged prior to use.
replaced the relay in case there was voltage drop
The only think different on this engine to all my others is a set of boysen reeds. I'm considering swapping these with some CCMS reeds that where on another motor that is in bits atm.
Any other suggestions?
CheersLast edited by 225XCL; 01-13-2020 at 05:37 PM.
Sold the old Formula 233.
Now have a 22ft Whittley Sea Legend powered by 225 Excel with Pro-V 200 covers.
01-14-2020, 02:35 AM #2
An engine that is hard to start when cold is typically lean, so try bigger idle jets.
01-14-2020, 03:12 AM #3
Thanks for the post, that's interesting, the carbs are all factory jetting.
If I wind out the mixture screw that would help if that's the case wouldn't it?
Once its running it runs perfectly.
01-14-2020, 04:16 AM #4
Try the pilot screws!
(But remember their starting settings)
Also, as far as I remember, the Excel had an electric primer circuit. (or was that the Special?).
I used one of those on an engine without choke, and it started like an EFI.Markus' Performance Boating Links:
225XCL thanked for this post
01-14-2020, 07:39 AM #5
I assume you are priming the fuel bulb to fill the carbs before cold starts
225XCL liked this post
01-14-2020, 10:27 AM #6New Member
- Oct 2017
- London, Ont. Canada
Make sure that all the choke plates are closing completely.
01-14-2020, 07:27 PM #7
LittleCharger liked this post
01-14-2020, 07:28 PM #8
01-15-2020, 08:24 AM #9Markus' Performance Boating Links:
01-15-2020, 08:43 AM #105000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
The draw holes in the choke plates on a lot of the Yamys is huge....too big to get a good draw when cranking....I found some snap in plugs at a hardware store that would pop in to the holes and block them off ...did bunches of them back when we were selling them motors new...much improved cold starts..
225XCL, InjectorService thanked for this post
01-17-2020, 01:50 AM #11
I am loosing the plot, the manifold is the same cast as the 6R5 but its not plumped for the primer.
So back to the drawing board.
Reset all mixture screws from 3/4 to 1 1/2 turns out. We are getting some long over due rain atm so checking the choke will have to wait for a bit.
If these don't work I will try the carbs from a different powerhead that was having no issues starting and work from there, I'm still tempted to swap the reed plate out.Last edited by 225XCL; 01-17-2020 at 06:04 PM.
01-18-2020, 11:05 AM #12
Pro Max 150 hard to cold start
By Warrenroadie in forum Technical DiscussionReplies: 5Last Post: 04-10-2017, 12:52 PM -
OMC Tech: Hard To Start 235 Only When Cold
By Brian GT 2.6 in forum Technical DiscussionReplies: 21Last Post: 09-13-2008, 08:26 PM -
2.5 Efi Hard To Start When Cold
By liberatorx2 in forum Technical DiscussionReplies: 7Last Post: 10-07-2002, 08:03 AM -
94 260 hard start - cold
By UROSKEE in forum Technical DiscussionReplies: 15Last Post: 04-20-2002, 12:01 AM -
Hard cold start - EFI
By DaveR in forum Technical DiscussionReplies: 0Last Post: 03-24-2002, 05:41 PM
