Results 1 to 13 of 13
    May 2001
    Charlotte, NC
    WTB: Early I6 Merc LU case
    I’m looking for an early Merc I6 lower unit case, casting number 1623-5886. I really only need a good case w- a nice skeg and not the internals.
    Thanks-
    Celina, Ohio
    Mine is 1623-3912. Its off early 70's 80hp
    Case is perfect. Complete.
    Attached Thumbnails Attached Thumbnails 20200114_170545.jpg   20200114_170638.jpg
    Dec 2001
    different case....1/2.3 gears....pin case....
    Celina, Ohio
    It is 2:3 ratio. I didn't know if the older cases interchanged or not. I know the later 850xs and 1500xs would not interchange internal wise. There is the same casting lower on ebay right now that says it has 1:78 ratio.
    May 2001
    Charlotte, NC
    LC, I believe all the 1350s (70-71) were 1.78:1 gear ratio??? Where the majority of the I6s after were 2:???? But not sure if the case casting were different.
    Dave can you school me?
    Dec 2001
    Being a 1980 case.... not sure.... but I think all 1/2.3 cases were pin type D/S..... the early 1.78 cases had different size /straight cut gears.....Been a long time.......SCT is looking for an early case..... How early? I may have........The early ones had small H2o pickups.... steel shafts.... blunt nose.... or a newer one with fine splines... and a Xs style long skeg????
    Celina, Ohio
    1980 case?? This came off a friend of mines 1970 80 hp
    Dec 2001
    SCT... if your looking for a 1.78 case I might have one......w/no guts.....have some whole cases....What is your application goning to be?
    Dec 2001
    Large car .... sorry .......got the year wrong.......some 1970s might have 2/1 ratio.....but most merc lowers were 1/2.3 on 80s......I think they were different.... not sure. Its been a while......have to rattle in the shop and look..........
    Jun 2021
    downers grove, IL
    Hi - I am new to this forum and I know this thread is over a year old but am hopeful for a reply.
    I am looking for a Mercury Lower Unit Model 1623-3912. Largecar91 - Do you still have one? Or anyone else?
    Thanks
    Dec 2001
    What do ya need 20 or 15 inch?
  12. #12
    Jun 2021
    downers grove, IL
    Not sure exactly what measurement you are referring to. If it's it front to back on the top side it is 20". Thanks
  13. #13
    Jun 2021
    downers grove, IL
    Update - I was able to get a used lower unit 1623-6658 from a guy in the Wisconsin Dells area. It was an upgrade from the 1623-3912 as it has a stainless steel drive shaft. The leading edge is also larger which caused the wake to flatten out.
  1. Early early 200 merc
    By Tripps in forum Misc. Parts and Accessories
    Last Post: 08-30-2016, 07:25 PM
  2. Early CLE case
    By jjamieson7284 in forum Lower Units
    Last Post: 02-14-2016, 09:42 AM
  3. early mod vp gear case (cle) with drive shaft
    By Gilles1 in forum Lower Units
    Last Post: 12-11-2014, 06:22 PM
  4. Mercury Tech: cle gear case early and late model compatability
    By jas638 in forum Technical Discussion
    Last Post: 08-06-2010, 02:46 PM
  5. Mercury Tech: Best Case...Worst Case...fixing this 2.4 Merc?
    By imq707s in forum Technical Discussion
    Last Post: 12-02-2009, 09:25 AM
