Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
    Jun 2009
    Bristol, Connecticut
    Chipped Lower Unit Skeg Needs Reshaping
    The very back edge of a lower unit I have is cracked. I was thinking of cutting it with a grinder wheel to shape it. It would take about 1 inch off from the very bottom and I will try to keep the same basic shape as it comes of the bullet part....What do you guys think??? Is this something you guys do rather than welding or throwing it away?
    Pekin, IL
    Be careful shortening the skeg if you are using a surfacing prop.
    Rock
    Team Junk
    Jun 2009
    Quote Originally Posted by rock View Post
    Rock
    makes sense...1 inch isnt too much....???
    Jun 2009
    Looks like a non coned non surfacing. You'll be ok with it buried deep in the water
    Jun 2009
    Think I’m gonna put a cone on it
    Jul 2002
    FT WORTH, TEXAS
    dont take it personal i would not spend a dollar on this empty just my experiences in gear case work
  8. Likes rock, Capt.Insane-o liked this post
  9. #8
    Feb 2014
    Missouri
    Epoxy on a skeg guard/protector thing
    dubble check on high speed operating though never had one over 50 myself but it ran smooth
  10. #9
    Get another lower/case. Sell that one cheap.
  11. Likes Capt.Insane-o liked this post
    May 2016
    keys
    If your gonna cone it, then just add some material back to it when you weld the cone and torque tab on. I know welded skegs are taboo on this site but it's so far down the skeg that it shouldn't ever see enough side load to break again, even if it did you'd likely never even notice it
  13. Thanks Aaronhl thanked for this post
  14. #11
    Jun 2009
    Thanks for the all the input guys this is why I wanted to post it.
    This lower unit appears empty because I took the bearing carrier out of it. I have most of the parts for it. I took it apart because the driveshaft wont spin. I was thinking of taking the driveshaft out to shorten it to 20" and getting the whole unit working again...
    This lower unit came off a 135hp mariner I bought for $500 so this lower unit didn't really cost much...
    Jul 2002
    FT WORTH, TEXAS
    depending on how its used maybe your life for those who don't know the back of the skeg is where all the serious voodoo begins!!! there are absolutely hundred's of empty case's available out there Good luck
  16. Likes Dave Strong liked this post
    Not worth the effort of putting a cone on
  18. Likes TEXAS20225 liked this post
  19. #14
    Dec 2006
    north end of the blue ridge, va.
    Is the possibility of you or a passenger getting hurt or killed REALLY WORTH the cost of an empty l/u housing??
    AIRWALK
    gettin' old ain't for sissies
  20. Likes TEXAS20225 liked this post
  21. #15
    May 2016
    keys
    My apologies to the OP for mentioning welding, and skeg in the same sentence on this site.
    That said. The case is repairable. However it should have paint removed where the case meets the skeg and inspected for cracks. Don't use a wire wheel as steel fragments could imbed in the aluminum causing cracks later.
    Here's a picture of a lower that's too far goneClick image for larger version.
  22. Thanks Aaronhl thanked for this post
  1. Propeller Reshaping
    By Chaz in forum Technical Discussion
    Last Post: 07-08-2013, 05:58 AM
  2. Chipped Prop Repair ?
    By DEYS in forum Props, Setup, and Rigging
    Last Post: 04-27-2012, 09:29 PM
  3. lower unit test results-cut skeg?
    By bill mason in forum Technical Discussion
    Last Post: 10-16-2001, 08:57 AM
