Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    Shawano,WI
    I never was a big believer of the hammer test but I'm no expert. My boat has core from the transom all the way to and past that little door in the bow. Core was just as wet in the bow as it was under the gas tank.
  2. #17
    Jun 2012
    Indiana
    Is that a 5" bolt on extension on the mid?
  3. #18
    Black Creek WI
    It wicks through the hull, even up the transom wood my 2 cents
    Quote Originally Posted by PaulR View Post
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
  4. #19
    Central, PA
    Great bass boat!
  5. #20
    Jan 2017
    PA
    I did some drill tests over the weekend and looks like the transom and most of the core are good thick glass with mat and nice white dry wood on my drill bit. The core over the pad on the other hand its thin resin and core is wet
  6. #21
    Jan 2017
    PA
    Decided I’m not going to take on this project just too much for me to take on at be moment
  7. #22
    Jan 2017
    PA
    QUOTE=capteliminator;3184855]Is that a 5" bolt on extension on the mid?[/QUOTE]Click image for larger version.
ID:	457749Click image for larger version.
    I didn't understand what you were saying until I looked at it again yesterday, certainly looks like a bolt on section to me... never knew that was a thing. Can it simply be removed?
  8. #23
    Shawano,WI
    It can be removed but you will need a shorter drive shaft. Probably be cheaper to find a different gear case?
  9. #24
    Quote Originally Posted by Burkulater View Post
    I didn't understand what you were saying until I looked at it again yesterday, certainly looks like a bolt on section to me... never knew that was a thing. Can it simply be removed?[/QUOTE]
    Depending if it has driveshaft and shift shaft extensions. Pull the lower off and look. Probably needs an impeller anyway
  1. Hydrostream Vasseret - $2500 (West Mobile)
    By stock10 in forum Ebay Listings and Other Internet Listings
    Last Post: 06-15-2017, 08:03 PM
  2. I Bought Hydrostream Race Boat!
    By thaw ripper in forum Racer's Hangout
    Last Post: 11-09-2009, 08:21 AM
  3. 91 hydrostream vasseret prop ?
    By live2ride31 in forum Props, Setup, and Rigging
    Last Post: 08-27-2006, 08:35 PM
