Results 1 to 5 of 5
    Jul 2018
    Smyrna GA.
    Motor replacement?
    Blew up 1990 evenrude225 still runs but rod knocked golf ball size hole in block. put 81 johnson 150 not lot of top speed 72 with 26 pitch big ear chopper. have an 85 johnson 140 thinking bout installing but dont know bout speed. Might just buy used merc 200. Any thoughts? Boat is a 1984 skeeter wrangler120hp 15ft 800lbs not most stable hull they but fast, made concave speed pad flat (fixed porposing problem and got more 6mph on top) dont know maybe boat too light to run v-6’s or what any suggestions? Running 9in plate low water shaft even w pad. Or get better boat?
    The hull is basically a Hydrostream Viper
    Jul 2018
    Smyrna GA.
    Thanks capt insane-0 know where can get a merc 200-260? Can buy or got Good bit of parts and bunch of new shift cables!
    A stock 200 would be plenty. All I have about now is a 05 xr6 that I probably shouldn't sell due to the fact it's probably the nicest running motor Ive ever had.
    Sep 2017
    Ashland city tn
    Quote Originally Posted by HaulNbass View Post
    I think u can rebuild a new motor (2.5 200) for bout same cost as a used one. And can do the mods that work for you
  1. Mercury Tech: V6 200 hp motor mount replacement
    By hdoc in forum Technical Discussion
    Last Post: 10-21-2014, 04:10 PM
  2. OMC Tech: Tilt/Trim motor replacement.
    By RevmanII in forum Technical Discussion
    Last Post: 07-28-2011, 03:03 PM
  3. Trim pump motor replacement XR6
    By factoryfive in forum Technical Discussion
    Last Post: 08-28-2010, 11:39 PM
  4. Replacement motor for CMC jackplate?
    By Mach2 in forum Technical Discussion
    Last Post: 06-18-2003, 08:59 PM
  5. Motor mount replacement
    By PaulO in forum Technical Discussion
    Last Post: 07-11-2001, 05:41 PM
