Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
    Jul 2005
    AZ
    HELP..Sportsmaster on OMC
    Looking for who does the adpaters for
    Putting Sportsmasters on an omc and any links to posts that have done it..
    I had all the links and somehow lost them.
    Thanks Michael
    '84 Checkmate Convincor
    Mar 2015
    bunnell FL/old town FL
    Not sure who does the adapters mine doesn’t use an adapter it was made to bolt up to the omc mid pm bajamerc on here he’ll be able to help u out
    2003 mirage ski racer with e-tec power
  3. Thanks mrichartz thanked for this post
    Likes mrichartz, oldschoolltv, baja200merk liked this post
    Nov 2003
    Kevin (baja200merc) is your man. He does all kinds of adapting sport masters to OMC stuff.
  5. Thanks mrichartz thanked for this post
    Likes oldschoolltv liked this post
    Jul 2005
    AZ
    Thanks! Spent an hour earlier trying to remember who it was and could remember vaguely Kevin but was sure who or what his screen name was...lol
    Thanks Michael
    PARADISE /Naples
  8. Thanks mrichartz thanked for this post
    May 2002
    Harriman, TN
    What all does it take to put a sporty on an OMC?
    Jul 2005
    AZ
    If someone can explain exactly..
    Not positive I forget exactly..but
    Some make adapters ..
    Or weld in slugs and drill them for omc bolt pattern.
    Then make custom mounts/cable etc for the shifter
    And then the driveshaft..
    And water pump
    Michael
  11. Thanks ssv1761982 thanked for this post
  12. #8
    PARADISE /Naples
    Monty just pined my OMC lower it stayed together on a 100 mph lake boat.
    I would talk to him about your needs, might be able to save you some coin, Monty is not a bull chitter.
  13. Likes dgscroggs, ssv1761982 liked this post
  14. #9
    Mar 2015
    A pic of mine , no adapter needed for this one, you also have to have a diff shift shaft seal housing to clear the mid i also have an omc water pump housing with a merc impeller on the inside
    Attached Thumbnails Attached Thumbnails DCFE3187-F3CA-4B55-A4C4-B43446F70F71.png
  15. Thanks mrichartz thanked for this post
    Likes mrichartz liked this post
  16. #10
    7 Post(s)
    The 3.0 Sporty is close to a bolt up, the 2.5 is not.
    The 2.5 water pump will fit w/o modification, the 3.0 will not.
    The OMC shift rod is raised/lowered to change gears the Merc Rotates.
    Also need to mod the cooling tubes.
    Ive done a couple of the 2.5’s.
  17. Thanks mrichartz, ssv1761982 thanked for this post
  18. #11
    Jul 2005
    AZ
    Will be calling to find out exactly best way etc..
    I'd rather do it myself if possible..
    But also know when not to...
    I knew that there were a couple different ways knew one I was not going to be able to do.
    I had links and pics if all of it but lost them some how.
    Thanks Gary
    Michael
  19. #12
    PARADISE /Naples
  20. #13
    Jul 2005
    AZ
    Thanks, was actually just typing asking what he did and pinned?
    I have mine carriers pinned going to read that now
    Thanks James .
    Michael
  21. #14
    Jul 2005
    AZ
    Yea pinning the carrier..I started doing that to my lowers a long time ago was shown to me by one of racers back when..I was still young ...showed me someone's carrier and the groove it was wearing in..had come loose and just needed to bolt/pin.. it in..
    Michael
  22. #15
    Mar 2009
    holiday
    Kevin is your man. He has put the time in to figure out what works and is trouble free. Probably have 200hrs or more with a sporty under an omc moded by him.
  1. 3.0 Sportsmaster
    By ASPB in forum Lower Units
    Last Post: 07-11-2015, 01:46 PM
  2. Mercury Tech: sportsmaster
    By Superbender in forum Technical Discussion
    Last Post: 09-04-2009, 12:51 PM
  3. sportsmaster
    By water in forum Technical Discussion
    Last Post: 05-20-2008, 07:30 AM
  4. sportsmaster
    Last Post: 04-25-2008, 08:08 AM
  5. sportsmaster
    By tizcri in forum Technical Discussion
    Last Post: 08-03-2007, 07:11 PM
