Results 1 to 9 of 9
Thread: Idle jets and idle rpm
01-10-2020, 09:26 PM #1
I'm runnin wh46s. Had stock 46 in idles and bumped em up to 50s , what is average gain in idle rpm that u have experienced?? 100 300rpm ?? Dosent have to b exact.
01-11-2020, 01:46 PM #2
A 200 with 46's should have come stock with 54 or 56 idle jets, Idle change will depend on how rich or lean it was running with the 46, motor height, and pick up timing all have an effect.
01-11-2020, 02:19 PM #3
You are correct. I think suppose b 56. Pulled the idles from wh22s. 46 idles wasnt all that rich, went up to 50s and idle rpm came up quite a bit and lean sneeze after idling for min. I replaced couple throttle shafts , had play and was allowing a crack in butterflies. Sumtimes would close and sumtimes wouldnt. Of course more idle timin helped to. If rain would stop I'd go test again. The idle rpm is fine if I can loose the sneeze every now and then hopefully the shafts fixed that as they do seal tighter now
01-11-2020, 02:44 PM #4
If 50 doesn't fix lean sneeze try 54.
01-11-2020, 02:51 PM #5
Wouldnt that make it worse leaning it out?
01-11-2020, 03:22 PM #6
01-12-2020, 09:18 AM #7
Ya no biggie. Hopefully I'll get to test it today and c what its doin , if it still tries to sneeze I'll turn idle timin up hair more ,
01-12-2020, 05:49 PM #86000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
I’m not sure what to run with the thermo valve off. But it will be leaner when cold.
Just play with the jets and timing till the idle and low end power fell like what you want
01-12-2020, 06:21 PM #9
No thermal valve. Runnin wh46s. I got more all around with 46s. Thinkin bout tryin set 20s next
Idle air jets
By FMP in forum Technical DiscussionReplies: 3Last Post: 12-31-2018, 02:03 PM -
Mercury Tech: which idle jets???
By hydrohank in forum Technical DiscussionReplies: 5Last Post: 06-18-2009, 08:32 PM -
OMC Idle Jets
By tlea in forum Technical DiscussionReplies: 1Last Post: 10-13-2005, 12:19 AM -
2.5 idle timing/idle jets
By pinbuoy in forum Technical DiscussionReplies: 1Last Post: 07-15-2002, 08:52 AM -
Idle air jets
By jody in forum Technical DiscussionReplies: 1Last Post: 12-28-2001, 07:39 PM
