Results 1 to 7 of 7
    Oct 2009
    Lake Conroe, Tx
    Taking paint off a block
    Whats the best way to take paint off a Merc block? I used sand blaster a long time ago and didn't how long it took to clean the sand out. Is there some type gel or liquid paint remover that you guys have used? Thanks
    AIRCRAFT remover. The past stuff. Not the spray
    Sep 2017
    Ashland city tn
    Quote Originally Posted by roadkill636 View Post
    I seen sum that stuff at local orileys auto parts , the price was expensive, never used it but sounds like sum bad chit
    Jan 2020
    Pinole, Ca
    Mariner paint is easy to get off...merc paint is not. But then again, the sun takes mariner paint off on its own, but it doesn't peel merc paint in the same way.
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    Pekin, IL
    Last one i did was media blast with walnut shells. Finished job was good but it took forever.
    Rock
    Team Junk
  6. Likes 25two.stroke, keefallan liked this post
    Aug 2020
    Dickson, Tennessee
    Look for "methylene chloride" as the active ingredient. Thats the good stuff. The EPA started cracking down on it last year so get it while you can.
    Sep 2011
    maryland
    I have used soda numerous times for cleaning the paint off of an engine block. When you are done, wash it with soapy water and soda is gone. And it doesnt hurt the aluminum or anything..........but be warned...............the snot is gonna run if you dont wear a respirator..........I just felt it was a way to clean me out.....like eating a good bowl of chili!! no harm to me just made the snot run..........
    I will use soda anytime I blast an outboard motor. ....
  1. Stripping Paint from engine block?
    By 2.5-21 in forum Technical Discussion
    Last Post: 02-26-2012, 03:17 PM
  2. Block Paint
    By Flatlander in forum Technical Discussion
    Last Post: 09-20-2010, 12:22 PM
  3. Taking paint off cle.
    By SkeeterD in forum Technical Discussion
    Last Post: 01-28-2007, 04:28 PM
  4. Block paint...
    By Superdave in forum Technical Discussion
    Last Post: 01-09-2002, 10:48 AM
