Results 1 to 15 of 57
01-07-2020, 06:47 PM #1
260 Big Bore mystery motors??????
Looking for some info on a couple of 260's I picked up sold as parts motors. I can take apart and assemble these motors but I don't know much about bore sizes and porting and that type of thing. I've had a lot of 260's and Drags over the years but I've never seen anything like these two. They have Bridgeport style o-ring steel sleeves with a 3.640 bore with custom installed support bridges in the block. The pistons have a domed center and one head has an offset chamber. The heads are stamped port and starboard.
The top of both blocks have been cut into for what looks like a specific reason then welded up. Both water cavities have a tube welded into them and the water jacket by the exhaust divider has been milled out completely, stock has three hole drilled in those slots.
I posted some of these pics in another thread andErik Kiser mentioned the nameAlex Hledin as a possible builder? I'd like to possibly bring one of these motors back to life as the pistons look pretty good in one of them but I have no clue where to start looking for a sleeve or new rings. I need one sleeve for sure or I could use one from the other block?Last edited by PaulR; 01-08-2020 at 09:14 AM.
01-07-2020, 08:35 PM #2
The sleeves may have come from Alex, but the welding and umm..machine work is pretty crude to be from his shop..
LittleCharger liked this post
01-08-2020, 07:54 AM #3
.015 over 3 liter sleeves in a 2.5 block with a bridged exhaust port. Don't see that every day.
RockTeam Junk
01-08-2020, 08:41 AM #4
That looks like some Gordon Montigue work. I remember Chaz and i were having a conversation a couple years ago about Gordon having this idea.
01-08-2020, 09:19 AM #5
Few more pics, one is of a stock 2.5 piston in the cylinder
01-08-2020, 09:23 AM #68000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
Alex did stuff like that but he absolutely didn't do that welding if I ever can get up by you I will check it out Gene did a couple of experimental motors like that too check with RBT I think he may have had one like this but a 2.0
Capt.Insane-o liked this post
01-08-2020, 10:10 AM #7
Alex Hledin.
2023 TUFF 25
Michael J Giesler liked this post
01-08-2020, 10:25 AM #8
I did some research on the name Alex Hledin here on S&F but most of the threads are fairly old. What are the chances of getting sleeves for these things and are the pistons a limited run or are they a production piston...OMC???
01-08-2020, 11:39 AM #9
Hledin has built a lot of performance stuff. I had 1 of his 6 pack intakes and a set of dual plug 21cc heads. All on a nitrous Bridgeport Moorman built many moons ago.
RockTeam Junk
01-08-2020, 11:59 AM #10
Hledin facebook page:
https://www.facebook.com/Engine-Perf...3376959165919/I CAN ALWAYS MAKE ANOTHER DOLLAR, BUT I CANNOT MAKE ANOTHER DAY
01-08-2020, 12:00 PM #115000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
Sleeves and pistons all look custom built. Nothing I see looks too trashed. Why not piece one together with the best parts and see how it runs. Looks awesome to me. Somebody did a heck of allot of work there. Do you have the full operating systems to go with them? Subscribed.
01-08-2020, 12:07 PM #12
01-08-2020, 12:18 PM #135000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
Should be a real torque monster. Keep us posted.
01-08-2020, 06:25 PM #14
PTR, performance through research. Alex Hledin, when mod-u was big he did some wild stuff and made huge hp. The 2.7 was a torque monster but had reliability issues. They would be interesting to see with a proper fuel map as one downfall was lack of effective fueling.
PTR is still at the top of the heap and very prominent in UIM F1, his current motors are pretty cool.2023 TUFF 25
PaulR thanked for this postCapt.Insane-o, Michael J Giesler liked this post
01-09-2020, 04:11 PM #15
I just looked over the blocks and I hate to cannibalize one to fix the other. The more modified motor turned over and all the pistons look fine, the issue with it is one sleeve is partly broken by the o-ring so it needs to be replaced. The other motor was stuck but no pistons were melted. These were used in saltwater and one piston was rusted in place along with the wrist pin bearings, also one cylinder is oversized.
At minimum I would need 3 sleeves 1 piston 2 full sets of rings and 2 sets of o-rings as far as custom parts go.
I don't use Facebook so I have no way to contact PTR
Merc small bore to big bore carb replacement and jetting question
By hollywood120 in forum Technical DiscussionReplies: 1Last Post: 06-09-2019, 08:47 AM -
To bore or not to bore, that is the question! Wisecos or Pro Marine pistons??
By RUNWME in forum Technical DiscussionReplies: 12Last Post: 09-08-2003, 08:48 AM
