Results 1 to 15 of 19
Thread: 300 and 250HP HPDI heads
01-06-2020, 06:39 PM #1
Hi Yamaha Guru's
I'm looking for details on the HPDI 250 and 300HP heads. In particular what the differences are in CC or even just PSI of the 2 motors.
I am taking delivery of a pair of 250HPDI's that need a rebuilding and would consider adding the 300HP heads if there is any benefit in it and i can still run it on standard unleaded (91 RON, 87 AKI for the folks in the states).
250HP head - 60V-11111-00-1S/60V-11121-00-1S
300HP head - 6D0-11111-00-1S/6D0-11121-00-1S
Also the reed cages, from my initial investigation the 250 and 300 have 6 petal reeds but the part number is different, do the 300 cages flow better?
CheersLast edited by 225XCL; 01-09-2020 at 03:19 PM.
Sold the old Formula 233.
Now have a 22ft Whittley Sea Legend powered by 225 Excel with Pro-V 200 covers.
01-10-2020, 10:28 PM #2
The 300 heads are definitely tighter than the 250's...but I don't know by how much. The 300 has an extra reed pedal...and a liquid cooled intake (I can't imagine that makes any difference).
'08 SRV
Yamaha 3.1 Phase III
01-11-2020, 01:05 AM #3
Hi Dok, longtime no chat. Thanks for the info so is that 7 reeds each side of the cage?
Cheers
01-11-2020, 02:24 PM #4
01-13-2020, 01:16 AM #5
I've decided to relax my head and put the thing back together stock.
After all I want to run it on 91RON fuel.
After posting this I'm going through all the parts I have and I took it on face value that everything was for 250, I'm looking at the ECU to see if its compatible with my lowrance HDS12, when the part number strikes me 6D0 and not 60V. WTF I say.
I then look at he heads and I have a pair of 60V's and 6D0's, of course the 6D0's are pitted and damaged after the blown piston. argh!!
So I have a 250 and a 300, I'm so close I gotta go for a rebuild of the 300, better source another head.Last edited by 225XCL; 01-13-2020 at 06:35 AM.
01-13-2020, 07:39 AM #6
Perfect. Just make sure you get the correct side head. There is a port and starboard lol.
'08 SRV
Capt.Insane-o liked this post
01-13-2020, 04:36 PM #7
Yeah I know. I think I have found one as well, just confirm seller will ship from Miami to Australia.
01-13-2020, 05:25 PM #8
Some Yamaha info here ... >
https://www.screamandfly.com/showthr...5-HPDI-rebuild
01-13-2020, 05:33 PM #9
Thanks I have read through that already but now that I'm actually doing my self will read it again and pay more attention.
01-14-2020, 03:22 PM #10Junior Member
- Mar 2014
- finland
- 7
DoktorC Show me 7pedal yamaha reed plate?
01-14-2020, 03:48 PM #115000 RPM
- Jul 2004
- ontario
- 182
- 18
- 59
- 24
01-14-2020, 04:09 PM #12
Ha! No question me...clearly I'm wrong lol. I ALWAYS thought the 300 had an extra set of reeds based solely on what Hydrotec was doing to the OX 3.1's and it sounds like I fell for the marketing. It was always the "300" front half on the 3.1's but there's not enough room for an extra reed on the 250 lol.
I swear I read it on the internet...it must be true! Thanks for the correction...little embarrassing but makes a lot of my HPDI fronts more useful lol.'08 SRV
01-14-2020, 04:55 PM #135000 RPM
- Jul 2004
- ontario
- 182
- 18
- 59
- 24
**From what I've gathered** , ALL OX's have a 5 petal front reed cage, 2nd gen HPDI's have a 6 petal reeds and a front half that will accommodate. 300's have 6 petal reed
s and the front half is water cooled. I suppose the theory is IF you are going to change the front half on a OX66 to fit 6 petal you MIGHT AS WELL put the 300 front half on to also get the benefit of "Water cooling" the intake tract. Cold air is better in any event lol.
01-14-2020, 05:04 PM #14'08 SRV
allstock liked this post
01-14-2020, 05:20 PM #15
I have a 250 and 300 and the reed cages look very similar. As for the water cooled front I will double check that.
Are the 250hp power heads same as 225hp?
By speedthriller in forum Technical DiscussionReplies: 6Last Post: 04-22-2014, 06:24 AM -
2006 250hp Yamaha Vmax hpdi tach settings question
By Sun Style in forum Technical DiscussionReplies: 2Last Post: 12-01-2011, 09:32 AM -
2006 Yamaha HPDI VMAX 250hp Thrust washer and hardware - Where to buy online ?
By Sun Style in forum Props, Setup, and RiggingReplies: 11Last Post: 11-09-2011, 09:39 PM
