Results 1 to 12 of 12
    Dec 2019
    Denmark
    Sport master vs torque master
    Can someone explain why and if a sport master is only better with speed above 80+ mph?
    im currently running a v bottom boat with a 225 optimax and top speed is around 76-80 mph and I’m not sure if I should build a bobs nose cone or similar on my torque master or not.
    my plan is to mount a transom low water pickup to be able to raise the engine higher an also experiment with another prop and maybe a bigger setback to gain more speed.
    Thomas
    Jun 2018
    Floating around
    Sporty has surfacing capabilities vs non
    Loudon Tn
    Tried a couple different torque masters on my Allison. EVERY time the prop would blow out a 90 mph!! Lot of transom lift. Not good for every application. my two cents
    Sep 2017
    Ashland city tn
    A coned torque master is faster than a sporty on alot of setups. Theres been a few people that say they rather have a coned tm rather than sm. I'm just goin by what a few have experimented with
    May 2001
    Maine
    The Mercury Racing site has a little explanation on the gear cases.
    Dec 2019
    Denmark
    Quote Originally Posted by Merc 2.5 View Post
    Can anyone confirm this or give some more info?
    Sep 2017
    Ashland city tn
    Use the search feature here. That's where I've read it. Least till sumone can confirm
  8. Likes tnelsmn liked this post
  9. #8
    Jul 2005
    AZ
    What boat? Just make sure one way valve is really sensitive.
    Just about transom mounted vs..
    My 380 Lazer was faster with the transom mounted pick up and no cone was over 100 that was 25-28 years ago...was just a plain lower unit nothing done to it except the plumbing for the water..
    you have less drag with the transom mount and no cone..but if your going to surface the lower the amount of drag isn't as bad because nothings in the water really..
    Had 2.4 efi Bridgeport and a modded 225 that spun the 32 chopper with ez..
    My motors now (different boat/motors) are better with the low water pickups and I surface these too...in other words different boat/motors/setup makes a difference
    That's why I asked what boat
    '84 Checkmate Convincor
  10. #9
    Dec 2019
    Denmark
    im running a fletcher Bravo 199
  11. #10
    Norway
    Hi!
    A sportmaster will slow you down if you run slower than 85 mph. The longer gearcase adds more drag if not surfaced. I mounted a Bobs on my Promax 300 and I did not gain speed. Top speed that time was 76 mph. The best gearcase for that set up was a Torquemaster with cambered skeg. Now I run a 400R and top speed is 89 mph. On this application the sportmaster is vital.
    Cheeers, Toffen
  12. #11
    Dec 2019
    Denmark
    Quote Originally Posted by Toffen View Post
    Hi!
    Cheeers, Toffen
    what is a “cambered skeg” ?
  13. #12
    Sep 2017
    Ashland city tn
    What runs the best is all bout boat and set up. Sm mite run better with that boat and set up. Tm coned run better with this boat and set up. just experiment or find other and that's already experimented.
  1. Why do sport and torque master not come with a trim tab
    By apexfx in forum Technical Discussion
    Last Post: 06-17-2014, 03:41 AM
  2. difference between torque and sport master
    By jcoats in forum Props, Setup, and Rigging
    Last Post: 09-06-2013, 09:57 PM
  3. torque master/sport master prop shaft (not fat shaft)
    By heather5520 in forum Posting Questions and Suggestions
    Last Post: 07-29-2011, 08:34 AM
  4. 1:75 Sport Master Gears in a Torque Master.
    By twig in forum Technical Discussion
    Last Post: 06-13-2008, 08:43 AM
