Results 1 to 3 of 3
Thread: Yamaha F70 gear ratio
01-04-2020, 06:27 AM #15000 RPM
- Sep 2006
- Michigan
- 153
Hello Yammie Gurus out there. I am wondering if the Yamaha F70 gear ratio (2.33:1) can be easily swap out to a lower ratio in the F50 (1.83:1)?
Are there any 15" mid section for these 4 stroke motors?
Thanks
mattmak77 thanked for this post
01-04-2020, 11:31 AM #2
It should fit the upper cases share the same part number, as do the crankshafts. As long as the driveshafts would be the same length it will fit. You need a full lower unit from the F50 though, not just a re-gear. These were from a 2016 F50 and F70.
Crankshaft p/n - 6C5-11411-10
Upper Case p/n - 6C5-45111-00-8D
You need a complete lower unit p/n - 69W-45300-01
This info is all assuming it is a new(er) unit. I used a 2016 for reference.
www.InjectorService.com
Call/Text - 204-326-0390
Mini GT thanked for this post
01-04-2020, 11:37 AM #35000 RPM
- Sep 2006
- Michigan
- 153
InjectorService liked this post
1988 Yamaha 200HP Gear ratio
By mragu in forum Technical DiscussionReplies: 1Last Post: 06-01-2013, 10:33 PM -
Yamaha Tech: Yamaha V6 200hp gear ratio ? max rpm ?
By Toffy in forum Technical DiscussionReplies: 29Last Post: 05-30-2013, 06:50 AM -
Yamaha gear ratio?
By KGb in forum Technical DiscussionReplies: 0Last Post: 06-13-2004, 06:52 AM -
Yamaha Lower Unit Gear Ratio???...
By VELOCITOY in forum Technical DiscussionReplies: 6Last Post: 08-21-2003, 05:01 PM
