Results 1 to 15 of 19
Thread: How big Setback
    Dec 2019
    Denmark
    How big Setback
    Hi guys
    im running a Fletcher 199 with a 225 optimax with a hydraulic jackplate.
    I’m about 80mph top speed with a 27p Tempest plus (blueprinted/labbed), but I’m running to flat and can’t seem to get it up flying on the back pad.
    any suggestions to ad a bigger setback or what to do?
    Attached Thumbnails Attached Thumbnails 935BCD00-83B4-4329-82D9-993EA38BA09A.png   198468FE-C5B7-41CD-9986-EB97FC65D893.jpg
    Put your motor down and measure where your propshaft is in relation the pad
    Dec 2019
    Denmark
    The distance from transom to prop shaft or horizontal from prop shaft to buttom?
    Boat level... propshaft level... distance apart?
    Dec 2019
    Denmark
    Sorry but I’m just a stupid demarkian (Denmark) haha
    Distance from red or blue?
    Attached Thumbnails Attached Thumbnails 02A407F8-6785-4D64-8ECC-7C69FEE42582.jpeg
    Red
    Dec 2019
    Denmark
    I just confused cause I’ve got a jackplate and therefore the level from shaft to bottom boat varies ��
    Dec 2019
    Denmark
    When I’m going top speed the shaft is about 2 inches under the pad
    Dec 2001
    how sound is the hull? Speed hook? 80 is good....... time to get a better hull......
  10. Likes Baker343 liked this post
  11. #10
    8 Post(s)
    The correct setback and height is the secret to a good life.
  12. #11
    Dec 2019
    Denmark
    What do you mean by “how sound is the hull - speed hook”??
  13. #12
    Jan 2005
    New York
    Tape a level to the bottom of the pad. Raise or lower the boat on the trailer till it is level. Now, lower the outboard till it is level. Tape a small level to the captivating plate. The one above the propeller where the zink is. Once that's level use a long enough stick to tape to the boats pad and reaches out to the nose of the lower unit. Measure the distance up or down from center of lower unit to bottom of pad. That's how to know where you are with setup
    Patriot Missile
  14. #13
    Feb 2005
    seattle
    if you setback the motor. the motor needs to be raise up. the water leaving the end of the boat raises up in relation to the pad.
  15. #14
    May 2009
    Ormond Beach, Florida
    There’s no significant pad on that boat. Most of your lift is coming from the lifting strakes. You will never get the boat to only run on the keel/pad, it’s too narrow. I don’t think you are going to find much more speed. You might try a prop with more bow lift. As for setback, you could probably move the motor back a bit, I’d try a 4” extension between the boat and current plate, it’s cheap. The only problem I see is the motor is already mounted quite high on the existing plate, it’s putting a lot of torque on the transom. It’s also going the make the transom sit lower in the water and on the first shot it’s already precariously low.
    Mark
  16. #15
    May 2016
    keys
    How much more speed is the stock lower gonna handle? I'd say without a cone or a sportmaster, your pissing in the wind.
  1. Single engine cat Setback or No setback?
    By 2.5-21 in forum Props, Setup, and Rigging
    Last Post: 02-08-2012, 05:12 PM
  2. Setback???
    By Vinnie in forum Props, Setup, and Rigging
    Last Post: 11-13-2009, 09:00 PM
  3. Less setback maybe?
    By Riverman in forum Technical Discussion
    Last Post: 09-13-2008, 07:48 PM
  4. Setback??
    By jcb164 in forum Technical Discussion
    Last Post: 06-30-2003, 06:56 PM
