Results 1 to 1 of 1
12-29-2019, 02:03 AM #1Junior Member
- Jan 2005
- Wellington New Zealand
- 21
280 Ros has spark and fuel but won’t run
Hi
My 280 has just been rebuilt after a major rod out side failure
Second hand block and front half crank and a matched set of pistons ( out of 260 second hand ) fresh heads and second hand harness and electrics
A bit of history the engine blew due to lean out and was replaced with a 260 that has been running on the boat for the last 5 years but was getting tired 280 rebuilt and dropped on weekend before Xmas fired up in garage without gearbox run for about 2 minutes turned off and gearbox fitted and headed 8 hours away for Xmas break
At the beach house went to fire up on nose cone water supply fired up ran stopped then not firing at all
It has spark while cranking I have pulled the injectors and cranked They have an even spray ( not exactly flooding but the injectors are out of the 260 that was running fine but tired )
What I can’t test is compression and fuel pressure I have tried my con ecu same result tried another crank angle sensor ( second hand condition unknown But was running on old 280 ) Relays bypassed to fuel and ignition still the same
Intermitantly will run or try to fire then crank without even a hint
Can we have got the the injection harness order wrong or the the coil order wrong the information of Color to injectors and coils would be useful Seems unlikely but need to be checked
I get a compression tester tomorrow and a fuel pressure tester tomorrow but I feel this isn’t the problem I also have a new fuel pump arriving on the courier tomorrow ( The fuel pump has sat dry for a few months)
I’m not confidant that fuel pressure is the issue and as the engine has spark I’m confidant the crank angle sensor is ok I don’t have a Diagnostic tool to check for codes
Has anyone got basic tests I can do without a diagnostic tool
Any help would be appreciated
Cheers
JohnNothing starts the day better than the sound of an open exhast Merc at full noise and smell of aviation fuel
1998 200 EFI Merc NO SPARK & NO FUEL
By Wakestocker in forum Technical DiscussionReplies: 39Last Post: 08-11-2014, 06:34 PM -
talk to me about fuel and spark plugs....
By cocacola in forum Technical DiscussionReplies: 5Last Post: 08-08-2012, 08:10 PM -
OMC Tech: OMC V4 Crossflow...problems w/fuel AD spark
By twright55 in forum Technical DiscussionReplies: 5Last Post: 08-16-2010, 11:07 AM -
spark or fuel??
By seebold1 in forum Technical DiscussionReplies: 9Last Post: 05-12-2004, 09:56 PM
