Results 1 to 15 of 85
Thread: Deglazing a cyl
12-24-2019, 09:32 PM #1
Deglazing a cyl
Didnt get much info on my little 2L thread so I'll ask this here.
Got a perfect runnin 150 , great compression etc. Motor is stripped down and has some chest mods , exhaust dump mods ,plates matched , no porting to cyls, thinkin ov goin ahead and doin a square port to pistons, gonna reuse old pistons. no (previous heat) issues and everything moves like just installed. What hone do I need to deglaze for new rings?? This is a free running mota , not afraid to experiment, gonna reuse most everything with serious cleaning , need a hone tho. What do I need to get?
12-25-2019, 09:14 AM #2
Welp .. you can start off here ...
Or end up here ... Either will do the job ..
Or stop anywhere in between ... here's where I got off the bus ..
12-25-2019, 02:40 PM #3
The ball hone , would u say like a 320 grit?
12-25-2019, 03:05 PM #41980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
tux974, CVX20SPRINT liked this post
12-25-2019, 03:14 PM #5The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Merc 2.5 liked this post
12-25-2019, 03:15 PM #6
I do not have a bore guage and have thought bout it also but with it being in such good shape , just wanna de glaze and new rings , budget/experiment build. I'm not gonna worry with little extra clearance, cyls dont have wear Marks,scuffs nothin still has cross hatch , truthfully I could put it back together with used rings and still have 120lbs , not a hi tech build. it's a spare powerhead for when (if) sumthin does go bad with one of the good powerheads.
But yes I still want it to run gud (strong) ,
12-25-2019, 03:18 PM #7
12-25-2019, 04:23 PM #86000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 431
- 64
- 434
- 452
Scotchbrite an tranny fluid.
12-25-2019, 04:53 PM #9
Wouldnt that b little to fine?
12-25-2019, 05:07 PM #10
This ...
You can buy one of these on flea-bay for around $100
If you can look at a block, rub your finger in the bore .. and decare it as being "gud" .. then 2.5, you're better than me ..
The Sunnen book call's for a bore finish between 220 and 280 when using a chrome faced ring.
Cylinder wall finish and ring seal kind of fall into the category of ... the amount of effort you put into it .. is proportional to the results you will get out of it ...
12-25-2019, 05:33 PM #11
https://www.amazon.com/PMD-Products-..._rd_i=15708741
this one works pretty good. JSRE cylinder straightener is also essential.death is certain; life is not
Merc 2.5 thanked for this post
12-25-2019, 06:16 PM #12
The bore guage will b a gud investment for me so I'll get one with a hone. But say ball hone for 2.0 wont work with 2.5 will it?
12-25-2019, 10:55 PM #13
Good price on that dial bore gauge ...
I've got a "bore jack" they are meant for NIC plated aluminum cylinders .. I doubt you could even fit the tool in a 2.0L sleeve, let alone move it ..
Ball hone 101
https://goodson.com/blogs/goodson-ga...ight-flex-hone
Dave Strong, tux974 liked this post
12-26-2019, 04:27 PM #146000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 431
- 64
- 434
- 452
S it ok to use a ball hone on a cyilinder with ports? seems like it will be wacking the port edges pretty good. i know it works for automotive apps. a bridgeport got me thinkin...
12-26-2019, 04:45 PM #15
deglazing a 2.4 ?
By daytrader in forum Technical DiscussionReplies: 10Last Post: 01-22-2016, 09:42 PM -
deglazing/honing
By MadMat in forum Technical DiscussionReplies: 19Last Post: 02-23-2011, 04:45 PM
