Results 1 to 9 of 9
    Nov 2003
    Portsmouth VA
    Reman transmissions
    I am looking at putting a reman transmission in a 2010 suburban. Any thoughts on Jasper or other manufacturers? Or any other suggestions? Hate to spend the money, but the truck is in real good shape otherwise and prices on newer ones are scary.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
    I would have a local shop do a rebuild or a trans rebuilt of their choosing. That way they pull and replace if it fails. Other option is to find a junkyard unit and cross your fingers...Jasper has a bad rep down here.
    https://www.monstertransmission.com/...B#.Xf_ZBqjYq00
    Nov 2003
    Portsmouth VA
    I have a local rebuilder but I need to decide how much longer I want to keep the truck. Also considering the warranty coverage both duration and location.
    Check with a GM dealer; the last time I did it the factory reman was cheaper, had something like 29 "updates", and had a better warranty.
  5. Likes XstreamVking, CVX20SPRINT, noli liked this post
    +1 with David - WI
    Nov 2003
    Portsmouth VA
    OK, checked around and went with Aamco. Our local Aamco is a large and established franchise and the owner is well respected around here with respect to truck, RV, and commercial work. He recently did one for my Godson that turned out very well. OEM reman was going to be $41-4600 depending on the dealer. I got a rebuild and reman torque converter, and new cooling lines, for $3400. 18mo/18K mi warranty. So far it seems fine, but time will tell. If anything remarkable happens I will post. Thanks guys for the feedback.
    Nov 2003
    Portsmouth VA
    Just a follow-up AAMCO trans is doing fine. Some towing and a trip to their mountains. About 14000 mile so far.
  9. Thanks XstreamVking thanked for this post
    Likes tnelsmn liked this post
    Jun 2010
    Ont.Canada
    When I worked for GM their SRTA rebuilds had a better/longer warr.than the original.Also if there was an issue other than maybe an external leak it didn't get repaired it got replaced,no questions asked.And you know there's a dealer every 50 feet if you ever ddo have an issue.
    If I knew it was going to last this long I would have taken better care of it.
    Chris
  11. Likes David - WI liked this post
    Aug 2020
    Try consider the warranty coverage both duration and location
  1. Testing Transmissions with S&F!!!!
    By njj502 in forum The Scream And Fly Lounge
    Last Post: 09-19-2010, 09:53 PM
  2. Drag Jet Boats w/ or w/o transmissions
    By vtec in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 09-15-2006, 10:06 AM
  3. anybody know anything about Paragon Transmissions?
    By kielbasa in forum General Boating Discussion
    Last Post: 10-21-2004, 08:24 PM
  4. Si;verado Transmissions??
    By Vinnie in forum Tow Vehicles and Trailers
    Last Post: 05-04-2002, 01:11 PM
