Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 46 to 60 of 114
Thread: Stuck Prop
  1. #46
    Is it off yet?
  2. #47
    Plainville, CT
    Is it off yet?
    Hasn't budged even with chains and gear puller. One last thing I think I'm going to try, based on some suggestions, are to drill out some of the rubber if I can, and pour a mix of ATF and acetone in there. If that does not work then cutting it will likely be.
  3. #48
    Nov 2019
    Canada
    If you have to cut it, cut all the way through the prop, rubber hub, and MOST of the way through the brass hub. Then split it with a chisel or air hammer. Better than cutting through the hub and touching the shaft with the grinder.
    www.InjectorService.com
    Call/Text - 204-326-0390
  4. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  5. #49
    Don't know if you tried PB Blaster. Every stuck part I ever ran into was freed up with Blaster if you spray it where it needs to go and give it time to work.
    1970 15' Allison/135 Chrysler stacker
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
  6. #50
    Plainville, CT
    Quote Originally Posted by Mark Poole ModVP View Post
    I've tried PB Blaster, Liquid Wrench, WD-40 Rust Release Penetrant. Each of them I let soak for days and re-applied numerous times. One of the problems is getting it into the right spots. Its obviously easy to get at the back of the prop but not the front.
  7. #51
    Ft. Lauderdale, Fl
    Quote Originally Posted by Glastron1987 View Post
    Put as much pressure on the puller as humanly possible.... when the prop blades start to curl under the pressure, you're half way there. With the puller, you should be able to either pull the prop off the hub or off the shaft....
  8. Thanks Glastron1987 thanked for this post
    Likes Glastron1987, James Thompson liked this post
  9. #52
    Either cut it off or live with it. No other choice..
  10. Thanks Glastron1987 thanked for this post
  11. #53
    Plainville, CT
    So for now I am soaking it with a 50/50 mix of ATF and Acetone. Will let that soak for another week or so, then try the puller again.
  12. #54
    Florida Keys
    You’re delaying the inevitable.......
    '95 STV "The Blue Goose"
  13. Thanks Glastron1987 thanked for this post
    Likes Capt.Insane-o, Glastron1987 liked this post
  14. #55
    [QUOTE=Glastron1987;3181766]So for now I am soaking it with a 50/50 mix of ATF and Acetone. Will let that soak for another week or so, then try the puller again.
    Waste of time as its not coming off. Again, do this....be done in a hour..(and another use canned air I knew about long time ago as good for bearing race install instead of freezer..)
  15. Thanks Glastron1987 thanked for this post
    Likes Merc 2.5, Glastron1987 liked this post
  16. #56
    Jul 2005
    AZ
    Wow definitely not in a hurry..
    '84 Checkmate Convincor
  17. Likes Capt.Insane-o liked this post
  18. #57
    Plainville, CT
    This is a spare LU, so time is not the issue as much as how much frustration I can endure.
  19. #58
    Jul 2005
    AZ
    Oh I figured that or winter...
    I should have said you are more patient than I !!
    Or I don't know might be one of those I refuse to lose and would do whatever to get if off w/o cutting....buuutt I doubt it and would have the cutting tools out..lol
  20. #59
    Plainville, CT
    [/QUOTE]
    Actually I did find your video a while back. That just very well may be my future. Nice family btw.
  21. #60
    Actually I did find your video a while back. That just very well may be my future. Nice family btw.[/QUOTE]
    My Merc guru here (lots of salt water) has cut a lot off, melt the rubber, all kind of ways and a lot of simple angle grinder off. But that Multi-Tool is the ticket!
  1. SS prop stuck on a V4 OMC gearcase
    By Sparkieboat in forum Props, Setup, and Rigging
    Last Post: 06-21-2015, 03:01 PM
  2. Removing prop stuck on shaft
    By twright55 in forum Props, Setup, and Rigging
    Last Post: 07-19-2010, 08:28 PM
  3. prop stuck on the shaft
    By rdkvector in forum Technical Discussion
    Last Post: 05-08-2010, 12:57 PM
  4. Removing stuck prop
    By riverrat321 in forum Technical Discussion
    Last Post: 06-27-2007, 06:06 PM
  5. What is the best way to get a stuck prop off?
    By PFord in forum Technical Discussion
    Last Post: 10-19-2004, 02:04 PM
