Results 16 to 30 of 114
Thread: Stuck Prop
12-19-2019, 06:00 PM #16
This has gotta be a salty mota???
12-19-2019, 06:01 PM #17
So you are going to take pics or video right!!!??
'84 Checkmate Convincor
12-19-2019, 06:03 PM #18
So have u been workin on it or gave it a break?
12-19-2019, 06:27 PM #196000 RPM
- Aug 2015
- Southeast
- 1,058
- 134
- 79
- 48
- 614
Maybe it's resolved... if you use a puller, don't just tighten the bolt until it comes loose. Snug it down putting some tension on it, then hit the center bolt with a hammer to pop it loose.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
12-19-2019, 07:21 PM #20
Glastron1987 thanked for this post
12-19-2019, 09:54 PM #215000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
12-19-2019, 09:55 PM #225000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
12-19-2019, 09:59 PM #235000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
12-19-2019, 10:05 PM #245000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
12-19-2019, 10:10 PM #255000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
12-19-2019, 10:14 PM #265000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
12-19-2019, 10:29 PM #275000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
So a lot of good ideas here. This prop is so stuck I am reluctant to think CRC Freeze alone will do the job, especially since it is hard to get it into where its needed. However it wouldl be cheap and easy to try it. So I may start with that.
The next step is to rig up some sort of puller. Its probably going to need hooks and chains to secure it "prop"erly. I like the red Proptopuss puller, but I think that is goin to be hard to get my hands on. I also like the idea of using a post type jack with the puller, and hitting it with a hammer under tension. I may end up welding something together. Whatever I use is going to have to be very heavy duty.
Cutting is a great idea. I have a heavy angle grinder and cutoff wheels, but will use this as a last resort.
Will try to post a photo or movie of what I try.
12-19-2019, 10:54 PM #285000 RPM
- Oct 2008
- Plainville, CT
- 799
- 417
- 22
- 377
- 65
So here’s my plan:
- CRC Freeze and hit with hammer
- Gear puller with hooks and chains; rap with hammer
- 5 ton hydraulic gear puller with hooks and chains
- Angle grinder with cutoff wheels (this is really the king)
12-20-2019, 12:33 AM #29
1. Not going to work.
2. Prolly going to **** something up and be mad.
3. See #2 only with more ****ed up and mad
4. Takes ten minutes.
12-20-2019, 01:22 AM #30Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Bolt the lower onto the motor , put it in the lake and jamb it in reverse, repeat , take the trim tab off for clearance first. If your lucky it'll break loose and whip right off to the bottom.
Glastron1987 thanked for this postGlastron1987 liked this post
SS prop stuck on a V4 OMC gearcase
By Sparkieboat in forum Props, Setup, and RiggingReplies: 9Last Post: 06-21-2015, 03:01 PM -
Removing prop stuck on shaft
By twright55 in forum Props, Setup, and RiggingReplies: 10Last Post: 07-19-2010, 08:28 PM -
prop stuck on the shaft
By rdkvector in forum Technical DiscussionReplies: 8Last Post: 05-08-2010, 12:57 PM -
Removing stuck prop
By riverrat321 in forum Technical DiscussionReplies: 10Last Post: 06-27-2007, 06:06 PM -
What is the best way to get a stuck prop off?
By PFord in forum Technical DiscussionReplies: 9Last Post: 10-19-2004, 02:04 PM
