Results 1 to 15 of 114
Thread: Stuck Prop
12-17-2019, 08:58 PM #15000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Stuck Prop
Inherited this lower unit, which appears otherwise to be good, with a prop stuck on it. Tried spraying all kinds of penetrating oil inside it, and have been pounding on it (the prop blades) for weeks in this positon with a small sledge hammer and piece of metal. It’s not budging.
Even tried applying heat but it caught on fire. I think it was the rubber inside the hub that caused that.
Any ideas how to free this up?
12-17-2019, 09:07 PM #2
Edit..was assuming your not worried about the prop?
Have you tried a puller?
Have even used a cheaper puller, cut some holes in the prop for the puller to hook into.
And try CRC frezze off it took stuff that wasn't budging..
Sprayed that on liberally on the nuts came right off
W/o spending a bunch of money on a prop pullerLast edited by mrichartz; 12-17-2019 at 09:11 PM.
'84 Checkmate Convincor
12-17-2019, 09:28 PM #3
Cut it off
'95 STV "The Blue Goose"
Capt.Insane-o liked this post
12-17-2019, 11:00 PM #45000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
12-17-2019, 11:02 PM #55000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
12-17-2019, 11:13 PM #6
Grinder w cut off wheel will cut it would need a few..
And a saw-zall w metal blade if you need to cut inside the prop
Pulley, just a cheap one off eBay 6" was like $15 I thinkLETS GO BRANDON.... LETS GO BRANDON
Glastron1987 thanked for this postGlastron1987 liked this post
12-18-2019, 05:47 AM #7
If you want to try and save the prop. get a Hole Saw that will fit just over the prop shaft without touching it. Cur the hub with the hole saw until there is no more metal. Remove prop. Then with a sharp chisel or (preferably a thin cut off wheel split the remaining stuck piece of hub and everything will come right off.
12-18-2019, 11:19 AM #8
Also this might sound weird but if you can heat up the shaft just enough to get a candle to melt on it and draw the wax in it will come off..wax will melt before the seal but still.. careful
Better yet if you can heat the prop but if rubber hub not likely to work
BUT NOT ENOUGH TO RUIN THE LOWER UNIT SEALS
Only reason I didn't mention it before..
I keep a couple in my tool box
12-18-2019, 12:08 PM #9
Angle grinder and a pack of cut off wheels
12-19-2019, 12:14 AM #10
12-19-2019, 07:24 AM #115000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
12-19-2019, 03:07 PM #126000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Did you take the nut off? Sorry always gotta ask.
Is it corrosion or did the splines get twisted.
Its not not healthy for the gears. You can put in gear and use a hammer to delock the splines by alternating walking the prop clock and counter wise.
A post type jack. And Chain is deadly effective. Takes good chain
Glastron1987 thanked for this postmrichartz, Glastron1987 liked this post
12-19-2019, 03:18 PM #13LETS GO BRANDON.... LETS GO BRANDON
12-19-2019, 03:45 PM #14
Just saw motv18s post yea a hydraulic jack with chain
With a little setup would pop it offLETS GO BRANDON.... LETS GO BRANDON
12-19-2019, 05:49 PM #15
SS prop stuck on a V4 OMC gearcase
By Sparkieboat in forum Props, Setup, and RiggingReplies: 9Last Post: 06-21-2015, 03:01 PM -
Removing prop stuck on shaft
By twright55 in forum Props, Setup, and RiggingReplies: 10Last Post: 07-19-2010, 08:28 PM -
prop stuck on the shaft
By rdkvector in forum Technical DiscussionReplies: 8Last Post: 05-08-2010, 12:57 PM -
Removing stuck prop
By riverrat321 in forum Technical DiscussionReplies: 10Last Post: 06-27-2007, 06:06 PM -
What is the best way to get a stuck prop off?
By PFord in forum Technical DiscussionReplies: 9Last Post: 10-19-2004, 02:04 PM
