Results 1 to 7 of 7
    Apr 2015
    OKC
    Lifting Johnson 300
    I picked up a couple of Johnson 300's from Houston and need to move them off the trailer. What size is the lifting EYE that bolts through the flywheel? I have looked online and am not seeing anything for the V8 - Just the V6 stuff.
    Thanks!
    Jul 2005
    AZ
    This is the one I used got it for my v6s
    Actually lifted motors, boat and trailer off the ground when
    When I was taking the old motors off...only an inch off the ground but worked no problem was up for 15mins so
    Had to move something and was fastest way
    2500# capacity
    Got it on eBay if you want link
    Michael
    '84 Checkmate Convincor
    Apr 2015
    OKC
    That is what I ran across on my search - I wasn't sure if it would lift the V8 or not. Thank you.
    Oct 2010
    Harrisburg,Pa
    Std OMC factory lifting eye works fine. Not sure I like the sm amount of threads on the above lifting eye,however if it was tested a 2500 lbs you should be ok.
    Nowthen, Minnesota
    Made my own for my v6. I have about $10 into it if I had to put a price on it. I just had all the material laying around the shop so I whipped it up in about 20 minutes. Works great.
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
    Calgary, Alberta
    The V8 uses exactly the same factory lifting eyes (there are actually two different setups) as the V6’s.
    Matt
    Jun 2001
    South Holland, Illinois
    I used the factory piece for removing the flywheel with a eye bolt threaded into it. Worked great.
  1. Johnson 200gt flywheel lifting bolts
    By seef158 in forum Technical Discussion
    Last Post: 05-09-2019, 07:52 AM
  2. OMC Tech: Lifting 1991 Johnson Faststrike off boat
    By 91nitro in forum Technical Discussion
    Last Post: 08-02-2010, 07:34 PM
  3. Lifting points for 2002 Johnson 90?
    By evogroup in forum Technical Discussion
    Last Post: 06-10-2007, 08:59 PM
  4. Looking for a LIFTING EYE
    By jeffbare in forum Props, Setup, and Rigging
    Last Post: 10-06-2005, 11:09 PM
