Results 1 to 15 of 18
Thread: hard to start
    Dec 2019
    texas
    hard to start
    83 mercury 115 inline 6 hard to start cold any ideas would be appreciated just bought this boat.
    Feb 2014
    Missouri
    Fuel air spark compression
    summer gas rvp is also bad for winter it doesn’t atomize well, and liquid gas doesn’t burn.
    One technique is to prim the bulb till hard, lift the cold start to full twice and then to half, apply choke and crank.
  3. Thanks brokeboater thanked for this post
    Dec 2019
    texas
    at the point of sounding stupid explain the cold start . i have a smalll boat with a little outboard first time with one this big
    Ft. Lauderdale, Fl
    Quote Originally Posted by brokeboater View Post
    The warm up lever on the remote control
    Jul 2010
    The Oldest City
    It has to be tilted ALL THE WAY DOWN!
    I carry a gun because a cop won't fit in my pocket.
    1987 Glasstream 15V
    1986 Mariner "Tower of Power" 115
  7. Likes whipper liked this post
    Prince George B.C. Canada
    Quote Originally Posted by Glasstream15 View Post
    My promax starts way better all the way down also. It starts up a little tilted but noticeably better the more level it is when cold. Ball hard choke on good plugs and good gas.
    Dec 2010
    Denmark
    Fine motor the old inline,,,
    If the motor hasent been started for a while, the gas have been evapurated from the carbs, leaving the oil back in them. and therefore the fuel seams to be more oil rich in the beginning. Also thinking that the power supply to the atarter can have influence on the start. when i had one it seams to throw the starter motor of and the starter had free spinn. and I would have to try 2-3 times until it started. But as sugested pump the ball hard and use the shoke until it starts. Other things can be the cause if it is some new problem that you experiensed. If it has an idle stabiliser box i would disconnect that for a start, as they are known to causes trouble. Mine ran and started with no problems after the first kinda cole start problems. I think that if it is beeing used frequently it is easy to start, an oppersit if it sits for long time between usage.
    Squeeze the piss out of the primer bulb until gas flows out of the carbs, fast idle to half way, choke and hit the key. It's been that way since 1957.
  11. Likes Dave Strong, mrichartz liked this post
    ...Prolongs starter life...
    ...Times two...
  14. #11
    Jul 2010
    The Oldest City
    Starting fluid prolongs starter life. BUT! It shortens motor life a bunch. It washes all the oil off everything inside the motor. Just for a few seconds but that's all it takes.
    1987 Glasstream 15V
  15. Likes Merc 2.5 liked this post
  16. #12
    Sep 2017
    Ashland city tn
    Once u figure out the rhythm of starting wont b to bad. They love fuel keep primer very hard and warm up throttle close to full and dont let off choke til it hits. Pretty much what Capt said haha. Or carry a coke bottle of mixed fuel and give carbs a squirt. Like I said they really like fuel
    Aug 2006
    GA
    Take Carbs Off. Cook them out. Go back with new Needles & Seats.New Bubble & Lines. Problem Solved
  18. #14
    I put a primer on my XS. Problem solved.
  19. Likes Dave Strong, nitro_rat, Merc 2.5 liked this post
  20. #15
    Feb 2014
    Missouri
    Even with fresh rebuild carbs are hard to start. If cold enough.
    Rebuild if its its more then once during the day. If the block is warm in any way and it takes choke and warm/cold start/ push button style being engaged to start. Go after the carbs.
    At 15f they can even die while running. Literally freezing (condensation) the fuel out of the air. That’s why it needs a good winter rvp. It helps keep the fuel in the air and useable.
    I hate ate when I get it backwards it’s high rvp for winter
  1. Hard Start
    By herk91 in forum Technical Discussion
    Last Post: 10-18-2012, 12:34 PM
  2. OMC Tech: 77 140 hard to start
    By switzer 140 in forum Technical Discussion
    Last Post: 08-19-2008, 07:32 PM
  3. 150 EFI Hard to Start
    By whays in forum Technical Discussion
    Last Post: 11-29-2005, 12:35 AM
  4. Hard to Start
    By Carter Powell in forum Technical Discussion
    Last Post: 03-14-2004, 10:36 PM
  5. 2.4 hard start
    By larrry j in forum Technical Discussion
    Last Post: 05-09-2002, 05:04 PM
