Results 1 to 11 of 11
    Baton Rouge, La
    Rear powerhead studs
    Need 8 of the longer rear power head studs for the 2.5 on a 1 piece plate. 4 each for 2 motors. Thanks Mike
    Cheaters never Win !!!
    May 2016
    keys
    2 different lengths depending on plate. I think older ones were shorter. Newer plates are thicker. Ask me how I know
  3. Likes tux974 liked this post
    Quote Originally Posted by Whaaaaat View Post
    On plate flange thickness.
    They are also 2 sizes out of the 4 back studs on the later 2.5 motors. You will have 2 part numbers because 2 longer by 1/4” in the coarse thread area so it goes deeper into the block for a stronger bite
  5. Thanks Whaaaaat thanked for this post
    Feb 2005
    thibodaux la
    Napa has them that’s where I get them from
  7. Likes tunnelmike liked this post
    I bought a length of all thread from Mcmaster carr and made my own.
  9. Likes tunnelmike liked this post
  10. #6
    Baton Rouge, La
    Levi , what do I ask for ?
    I will measure the flange after Church. Thanks Mike
  11. #7
    Gravenhurst, Ontario.
    If you can’t find em locally let me know what length you need.
    Ive got several scrap blocks with the studs still in em, I probably have what you need.
  12. Likes tux974 liked this post
  13. #8
    Feb 2005
    thibodaux la
    I just brought a short one and told them how long I needed and they had them
  14. #9
    Baton Rouge, La
    Sounds great !! I'll get the right length figured out and let you know. I appreciate the offer.
    Thanks for the info Levi. Mike
  15. #10
    Quote Originally Posted by tunnelmike View Post
    If you are using the new (thicker) flange plate you need 2- 2 1/2" & 2- 2 3/4". The longer area on the 2 3/4" will be on the coarse threads.
    The rest should be the same depending what can/down housing you are using.
    ~15" 4- 5 3/4"
    ~20 straight 2- 7" & 2- 5 3/4" I remember correctly also the same for the O/S can/down housing.
  16. Thanks tunnelmike thanked for this post
  17. #11
    Baton Rouge, La
    Pretty sure it's the thicker plate. I usually use 4 of the shorter long ones from the fishing set up so I'm guessing they will measure 5-3/4". Didn't get a chance today to measure plate thickness. Thank you sir. Mike
  1. Powerhead studs
    By rkmirage in forum General Boating Discussion
    Last Post: 05-20-2018, 09:59 PM
  2. 280 powerhead studs
    By laglass69 in forum Technical Discussion
    Last Post: 01-21-2011, 04:27 PM
  3. powerhead studs...
    By LakeRacer99 in forum Technical Discussion
    Last Post: 06-24-2003, 04:03 PM
