Results 1 to 9 of 9
Thread: Mercury Hub Question
12-13-2019, 03:30 PM #15000 RPM
- May 2001
- Maine
- 983
- 35
- 42
- 171
What are the pros/cons of the Mercury SSR 8M0101601.
Currently I run a 840237-C with the 4 rubber strips. I have heard the SSR provides smoother shifts but not sure how it will stand up on a STV with a 225 Sport XS.
Thoughts???
12-13-2019, 05:31 PM #2
I ran that hub on an STV Euro with a 225 Promax. Used it with a 30 Et Lightning and a Promax 4 blade. Worked fine in both. Was told to keep an eye on the slots where the drive sleeve slides into the adapter sometimes they will develop cracks. Mine never did but I didn't have a ton of hours on them either.
12-13-2019, 05:47 PM #36000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Always worked fine for me but it will take some effort to remove from a prop. Won't fall out like the solid hubs. Some have been able to hammer them out. I needed to use a bottle jack, socket and wood rigged underneath something heavy to press them out.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
12-14-2019, 06:00 PM #4Team Member
- Lake Coochiching, Ontario
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
Pro: smoother shifts
Con: very tight fit. Not going to work if you plan on moving it frequently from prop to prop. I have two of them to avoid the removal process
12-18-2019, 10:28 AM #5
Not recommended for surfacing applications (80+mph). The smooth shifting is really beneficial on center consoles with joystick engines that shift a lot more than our rigs. In higher stress applications the rubber portion can oscillate and cause failure.
2000 Triad Mod VP 280 ROS
12-18-2019, 11:02 AM #6\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
12-18-2019, 08:21 PM #7Team Member
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
I've never removed one. I put both in by tightening the prop on the shaft and forcing the hub into the prop. Getting either out would be a bugger.
Shift quality mattered a lot more with my old 225 Promax (idle 1100 +/-) than with my 200XS (idle 600+/-)
12-23-2019, 07:27 AM #8
Why does the Mercury solid hub insert get loose over time? When they are brand new they are nice and snug and after a season they are loose fitting? If all 4 plastic strips are still attached how or why would it get a little bit of play? Anything to be concerned with or is there a way to shim it to fit tight?
Triad V21 #002 - 15in DBR 300 xs
19' J-Craft - 175 Opti
18' Pontoon - 115 CT 4S
01-05-2020, 01:19 PM #91980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
V-bottom thanked for this post
Mercury Question
By Stricer0204 in forum Technical DiscussionReplies: 3Last Post: 06-26-2019, 12:35 PM -
Mercury 2.5 question
By clayton bigsby in forum Technical DiscussionReplies: 5Last Post: 07-30-2017, 10:28 PM -
mercury question
By superboat 21 in forum Technical DiscussionReplies: 1Last Post: 08-26-2008, 08:29 AM -
Mercury LU question?
By peedeerooster in forum Technical DiscussionReplies: 1Last Post: 08-21-2008, 11:17 PM
