Results 1 to 5 of 5
Thread: 240 sport jet info needed
12-10-2019, 02:55 PM #1
I have ran across a couple motors for a steal 1st is a 240 sport jet , story with it is , said it was over revved out of water, haven't even pulled a plug yet , and it will come.with a complete drop on 87 150 that's suppose to run. They bought the 150 to swap out the 240 until they figured out bout the crank. It's a o ring block 240 with newer lectrics.
I would like to use the 240 block and build a outboard with reg 2.5 crank and deck block for gasket heads and 16amp system. Also shouldn't it have the 7 pedal front with 5 pedal sj cages? Is there gonna b any surprises besides swapping crank? Any info on these appreciated also what block did they use to get the 240hp? Just a highly ported steel sleeve 2.5? Thanks guys
12-10-2019, 03:39 PM #2
I have one on a XB02. 32cc heads. Strong motor. Its 7 pedal. Just the crank different.
2012-2013 DSRA PRO STOCK HIGH POINTS.
2013 DSRA SUPER STOCK HIGH POINTS.
2014 DSRA SUPER COMP HIGH PONTS.
2015 DSRA SUPER COMP HIGH POINTS.
2014,15,16 ODBA SUPER STOCK WORLD CHAMP.
2016 ODBA SUPER STOCK HIGH PIONTS.
2017 ODBA Modified World Champ
Merc 2.5 thanked for this post
12-10-2019, 03:44 PM #3
So same crank as norm 2.5 just different spline?
12-10-2019, 04:35 PM #4
yep , I think it is 225 x block with different crank. Rates at 240 due to no hp loss thru the lower unit. hf...
12-10-2019, 06:27 PM #5
Nice hopefully when I get it home there wont b to much damage. All I know was revved to high out of water. But couldn't see any windows but still has all efi and stuff so hard see all of if
Sport F1 or SST 120 prop needed
By Eric T in forum Propellers WantedReplies: 5Last Post: 06-25-2019, 05:09 PM -
Scarab Sport 26 CC Info
By YeA 20sF in forum General Boating DiscussionReplies: 3Last Post: 10-15-2014, 10:58 AM -
Mercury Tech: 97 merc 175hp xr2 sport jet crank and bearing specs info needed please
By eurocar in forum Technical DiscussionReplies: 8Last Post: 07-15-2012, 09:22 PM -
Need info on Ralley Sport SuperBoat
By imq707s in forum General Boating DiscussionReplies: 2Last Post: 03-11-2004, 07:09 PM
