Results 1 to 12 of 12
12-09-2019, 05:33 PM #1Junior Member
- Oct 2016
- nassau
- 9
can anyone tell about what year this mercruiser is?
hi can anyone tell me what year they think this engine is? would greatly appreciate it send me a email with your guess kayabeach@gmail.com thank you to all
12-09-2019, 06:28 PM #25000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
Centre bolt valve cover and serpentine belt throttle body GM 88- 95 Possibly vortec pushing it higher closer to 95 - 2000 just a kick visual guess
12-09-2019, 07:05 PM #3Junior Member
- Oct 2016
- nassau
- 9
thanks buddy
12-09-2019, 07:43 PM #4Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Looks like an electric choke from here, chase the down the carb number. No block casting number?
12-09-2019, 08:19 PM #5Junior Member
- Oct 2016
- nassau
- 9
no just a engine i was interested in on craigs list i thibnk its like 2000 guys like it looks new! lol no kidding its in great shape but i dont want a 20 year old engine , im in the mrket to repower a 5.0 2000 tbi thing was suoer efficient on gas and in not a speed freak and i cant spend 10 gs for a new one, thanks for your reply
12-09-2019, 09:25 PM #65000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
FMP - I wondered the same but thought with the centre bolt covers it would be TBI and think the possibility of it being of being vortec - next gen by minamum looking at the head numbers - i believe that is reverse cooled and roller cam . Should have a tag on the block from Merc. ID of the HP and year . I had recently placed a call to my dealer for a 88-95 350 longblock "new" and they were only 2800 and they had 3 hundred available - so doubt the gen 3 is any more than a grand more new. Make the call and if it'I 3800 I think its cheap and just unfold your accessory drive on and change over intake and such -if your serious get the tag info - tin tag and or head number and make an effort to know if it' carb or TBI . Does look clean . New from GM is cheap if you have a decent truck but I will say sometimes it' cheap to just buy a newer piece what happened to the other block - i thought they were 5.3 . Usual intake leak cause the coolant into crankcase? I don' like to suggest a differant route but sometimes it' can make sense to upgrade if you take the time to think about it but your truck is worth little not running so make it a runner again . I know that wasn' the question here so dig for the tag o n the motor - side of the block peened on . Check for carb or TBI , head numbers block numbers - if it' cheap keep digging.
12-09-2019, 09:51 PM #7Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Number right under the Mercruiser sticker ? Maybe a 94
Home made Tunnel could use both for his motor yacht.
12-09-2019, 10:04 PM #85000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
I can' read it - i thought Merc used a tin tag over on the fuel pump side of block and I believe if it was vortec - 95 up it would have a plastic cover over the TBI and intake just like the trucks - i think you may be on the money with the gen 2 88- 94 .
12-10-2019, 01:50 AM #96000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Definitely a carb tbi intake. Not the later 90 turtle shell. I see more valve cover bolts like the 4 bolt or 2 bolt Been a while since I counted cover bolts.
I dont see the electronics though except the choke, so would need that if tbi.
Honestly i I don’t like photos just blur enough I can’t zoom in in a number any decent cell phone these days is that good.
12-10-2019, 05:45 AM #10Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Dont forget the valve cover studs went to the centre for a few years before the inlet bolts went vertical like a vortec.
I dont think cars did that did they?
You should be able to find the gm date code on the engine and the original serial number which Merc keep rocords on in case gm has a recall
12-10-2019, 10:07 AM #11New Member
- Dec 2019
- Nation wide
See if one of those stickers on the bell housing is the serial # I've seen Mercury do this, and also stamp the serial # in the block just above the circ pump on the right side
12-10-2019, 07:06 PM #12Junior Member
- Oct 2016
- nassau
- 9
HEY BIG SHOUT OUT TO ALL THAT HAVE REPLIED ! REALLY APPRECIEAT IT!! THINK IM GONNA SAVE AND GET BRAND NEW THAT COOL V6 THAT PUTS OUT THE SAME POWER AS A 305 V8 THIS SI WHAT IM STICKING IT IN! I LOVE THIS BOAT AND WILL NEVER GET RID OF IT! https://www.youtube.com/watch?v=qlp3y-Kp2TE
300xs year on year updates?
By Primal 98 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 6Last Post: 04-11-2017, 04:58 AM -
Happy New Year and i hope for all of us to get more MPH this year!!
By 17actionANT in forum General Boating DiscussionReplies: 0Last Post: 01-01-2009, 02:38 AM -
It was a bad year to be an investor, but a great year to be a broker.
By ssent in forum The Scream And Fly LoungeReplies: 0Last Post: 01-19-2008, 03:40 AM -
Difference in 2.0L blocks from year to year?
By ctered in forum Technical DiscussionReplies: 0Last Post: 11-13-2007, 10:34 PM
