Results 1 to 15 of 17
Thread: Mid (can) swap
    Sep 2017
    Ashland city tn
    Mid (can) swap
    I know there was a thread goin bout swapping can without removing powerhead, just wanna make sure I dont tear chit up. Trim it up , drop lower , support powerhead , remove lower mounts, and it should drop out ?? Tryin save on gaskets
    Sep 2017
    Ashland city tn
    Am I on the rite track with that? Dont wanna break plates or top mounts stuff
    Jul 2005
    AZ
    Gaskets are cheaper than breaking something...and probably easier than trying to support it etc...??
    Curious
    '84 Checkmate Convincor
  4. Likes tux974 liked this post
    Sep 2017
    Ashland city tn
    I'm pretty sure this is easiest _quickest way. I just cant member who it was sayin it. They will see it soon
    Jul 2005
    AZ
    Quote Originally Posted by Merc 2.5 View Post
    If you see the other post can you put link here..
    I mean I can see how it could be easier... Just always pulled it all apart
    Feb 2011
    HUDSON, FLORIDA
    That was me. plain and simple it was a ball br----r! i split a 1987, thank god i was a fresh water motor. i fought me a the way. permatex,antisieze, pb blaster, gloves, brake kleen, wd40. gasket scraper a must, razor blades/holder. refrain from using a hammer a all costs. put in new lower seals too. youll need anarobic gel red sealer. dont get burned, o:reilly auto had it, 6$ anywhere else 16$. im ready for the l/u tomorrow. ph still hanging.on the hook. i grouped my nuts,washers in zip-loks, marked. order of assembly, cause i cant rember s t!
  8. Likes mrichartz liked this post
    Feb 2011
    HUDSON, FLORIDA
    there are bolts under powerhead into adaptor plate. how can you get at em with ph on? ph studs go thru the whole deal, adaptor and can.
    Jul 2005
    AZ
    Quote Originally Posted by KIRCHNER View Post
    Yea that's what I was wondering
    Dec 2001
    A lot of work to make some noese....3 rear bolts
    A few $'s or a little work in savings are just not worth a piece of mind that all is back together properly!......JMPO
    KIRCHNER, they leave the bolts hanging.
    TX......somewhere?
    its simple.. john tiger did an article showin' all involved when they were doin' "tuner test".. I do know that only way first time you had to loosen and "cut" lower mount bolts (first time doin' it) then replace insertin' them backwards (nut on can end) from original.. only four nuts (4 long power head studs) and three bolts (adapter to can)..
    can see reason they were doin' it for testin' and time considerations but really no other reason.. especially if ya only gonna do it one time...
  14. Thanks Merc 2.5 thanked for this post
    Sep 2017
    Ashland city tn
    Ok thanks tommy. I knew it could b done like that by lookin at it , but my mount bolts are still in like stock , I had pull lower anyway to get new pump kit , and I got this extra can drilled and tapped incase to loud I can take it back to quiter , I'll prob just order the gaskets with water pump , I'll see how it.goes
  16. #13
    Feb 2011
    HUDSON, FLORIDA
    The old gen2 ridgeback cans have different lower mounts. no mount covers. there intergrated part of the can. on top the adaptor is the mount.
  17. #14
    TX......somewhere?
    wrong thread.....
  18. #15
    Apr 2007
    Wilkesboro, NC
    It's not hard to do on a 2.5 and its much easier than pulling the power head if all you're doing is changing the tuner or removing the liner.
    1. remove the lower unit
    2. remove the large retaining ring on the bottom of the swivel pin. There also may be a small grounding strap at the bottom bonding the housing to the swivel bracket if so you will need to unhook one end.
    3. remove the nuts and washers on the long powerhead studs. There is 4 of them. 2 on each side
    4. remove the 3 bolts on the back of the adapter plate that goes into the driveshaft housing. These can be a little tricky. You may have to loosen them a little and allow the housing to fall down a little at a time.
    I did this on a 175efi a few weeks ago because the tuner was loose. I already had the lower unit off and was able to remove the housing, fix the tuner, and put it all back together in about an hour.
    If you are changing out the exhaust housing I would swap over the lower motor mounts and bottom yoke while I had both housings off the engine. If your new one still has these installed then it makes it even easier.
    Hope this helps
  19. Likes tunnelmike liked this post
  1. v-8 swap?
    By bluess02 in forum Technical Discussion
    Last Post: 07-12-2011, 07:12 AM
  2. '96 mid can swap
    By netvid in forum Technical Discussion
    Last Post: 07-20-2009, 09:31 PM
  3. 150 to 225 swap
    By brockshydro in forum Technical Discussion
    Last Post: 07-17-2009, 06:17 AM
  4. swap?
    By ASTROCRAZY in forum Technical Discussion
    Last Post: 03-29-2007, 06:25 PM
  5. efi swap
    By fishhead210 in forum Technical Discussion
    Last Post: 08-26-2005, 05:14 PM
